Not a very important question, but I'm wondering what the little diamonds are on my tape measure. It's a Stanley Fatmax from the UK © 2011. The first one is at ~488 mm (~19.2 inch), and then every ~488 mm after that along the tape, but they don't align with any regular measurement in can fathom.
Asked
Active
Viewed 172 times
See https://www.simplemost.com/heres-diamonds-measuring-tape/ for example – Jon Custer Mar 25 '22 at 02:01
https://diy.stackexchange.com/a/55152/18078 – Ecnerwal Mar 28 '22 at 22:21
It is an alternative framing spacing, used for studs, joists and rafters. It is an "identifier" for a stud layout much like the 16" center layout where you will get an even amount of spaces over an 8 ft. piece of material, or for that matter a 16 ft. piece of material as well.
Jack
- 34,187
- 1
- 24
- 60
1In other words, instead of 6 studs per 8' span, you get 5 joists for the 8' span. – BMitch Mar 25 '22 at 12:49
1@FreeMan — it varies from place to place, but those are usually drawn by architects that hate carpenters ;) – Aloysius Defenestrate Mar 26 '22 at 22:47
I have used those center marks myself. I was building an outbuilding using 2X6 oak salvaged from a barn, and needed to adjust my framing to work with the material I had. It worked out pretty good for my occasion. – Jack Mar 27 '22 at 18:45
@PaulUszak , don't count it out yet, I would think the roof is still done with framing. – Jack Mar 29 '22 at 02:54
