Does a burnt out florescent light bulb use the same amount of energy as new florescent light bulb does
1Where fluorescent lamps have a difference is more in the light output when new let’s call this 100% in just a few month the output drops by 25% or more and continues to have less light output. A lamp is considered at end of life at 50% but I see them all the time much lower than this but the ballast keeps the power constant so a lamp at end of life uses the same amount of power but is providing much less light. – Ed Beal Apr 02 '22 at 04:40
No, a burned out fluorescent tube doesn't use any power at all. It is an "arc light", and if the arc has not struck, then there is zero current.
Power is Watts = Volts x Amps. If Amps is 0, then Watts is 0.
If the filaments at the end are glowing (the pre-heaters) it's using a couple of watts at most.
There will be a few watts of load in the ballast, depending on the technology of ballast (a lot more for an old transformer-based "magnetic ballast", very little for a modern electronic ballast).
- 295,284
- 26
- 275
- 720
It's more about the ballast than the lamp. Most modern ballasts are electronic which can sense how much power is demanded and only provide that amount to flow. Old-style autotransformer type ballasts, because of their design, let current flow whether there is a lamp in the fixture or not.
- 81,744
- 29
- 133
- 227
- 13,121
- 10
- 31
