House was built in the 1950s. The light blue plastic tiles pictured are glued down with a layer of adhesive (light brown) that covers the span of the walls. The dabs of adhesive (darker brown) were used for paneling that covered the tiles. The tiles break easily as they are a 1/32" thick. Could any of these materials be asbestos?
Asked
Active
Viewed 90 times
3It is possible, but need to have it tested. The is usually little worry unless you are removing, sanding the stuff. You leave it alone, it usually leaves you alone. – crip659 Apr 04 '22 at 15:50
4I’m voting to close this question because the only way to know if something contains asbestos is to have it tested by a lab. Looking at a picture online won't cut it. – FreeMan Apr 04 '22 at 17:59
Instead of closing it, I would allow the topic starter to accept the answer below. These comments are in a small font and easily overlooked, and asbestos is dangerous stuff so I'd like any random wanderers in to understand that the answer here really is **'get it laboratory tested'**. – MiG Apr 05 '22 at 08:19
Duplicate (for all practical purposes - with asbestos, it really doesn't matter that much what the suspected item is) with an accepted answer here: https://diy.stackexchange.com/q/10222/18078 – Ecnerwal Apr 05 '22 at 13:05
House was built in the 1950's. Could any of these materials be asbestos?
Yes. They could be, the time era is right.
Or not.
You can't tell by looking at them.
A laboratory test is required to tell. Shop around and don't get overcharged for the testing.
- 10
- 245
- 533
