I've recently bought a house and removed the existing laminate. I was told when buying the house that the downstairs subfloor was sealed concrete. After removing the laminate flooring I found the below. My questions are:
- Could anyone confirm from the pictures that this is sealed concrete?
- If so, does the sealer look worn out to you?
- And if so, can I reseal by just cleaning and applying a new sealer on top or do I need to completely remove the previous sealer first?
I'd have expected a shiny/polished look if it was sealed concrete. Any help would be highly appreciated.
The reason why I'm asking is because when removing the laminate flooring that was there, the green padded tiles between the laminate and the concrete were quite mouldy and a bit damp. Not a lot, but enough to make me think there might be a damp/mould problem.
Thank you!
