14
Background:
A walk-in refrigerator with a remote refrigeration system includes an evaporator coil that requires a drain. The typical installation is an indirect drain (terminating above a funnel drain or floor sink to provide an air gap).
Observation:
I have recently seen installations and plans calling for an S-trap in the indirect drain line BEFORE the funnel drain/air gap.
[Evap Coil] ===/ /=== [S-Trap][Air Gap][Funnel Drain]====>
drain schematic
Image Source: HeatCraftrpd.com
My understanding was that traps provide a barrier of water that blocks gasses from entering the room through the drain.
Question:
What purpose does a trap serve immediately before an air gap?
TylerH
  • 1,010
AWaddington
It's preventing air movement through the drain pipe. Without it, cold air from the refrigerated space will constantly flow out the pipe, and warm air from outside will constantly leak in - wasting your refrigeration energy/expense.
So, it's doing exactly what you understand, but your understanding was perhaps limited to the case of "sewer gas" while in this case that's handled beyond the air-gapped drain, and the "gas" being prevented from moving is air - warm or cold.
    You can also get negative pressure preventing the condensate from flowing out. Instead is will accumulate in the unit and eventually leak inside the building. – JimmyJames May 03 '22 at 17:05
