I will be running wire through a basement ceiling (not a drop ceiling) and I would like to avoid cutting holes in the drywall. I know that the wire on its own would need to be supported and secured to the joists. However, if the wire is running through a conduit, does the conduit need supporting or can it rest on the ceiling?
Asked
Active
Viewed 711 times
In short, you don't need the conduit, and adding conduit probably makes support required. – Ecnerwal May 02 '22 at 19:38
A wire is generally not acceptable, period (exception might be a grounding wire as a lone wire.)
A cable (several wires in one outer jacket, such as NM/B aka "Romex® - a brand name) is NOT required to be attached where it cannot be accessed if it's a retrofit into an existing space, (apparently the case here) generally.
Conduit is required for protection of wires and IS required to be attached. There MIGHT be a pass for flexible conduit to be treated like cable for a retrofit, I'm not sure. There is for AC & MC cables, but not finding anything for flex conduit, even though it's very similar to AC & MC cables.
- 10
- 245
- 533
See https://diy.stackexchange.com/a/108789/18078 and https://diy.stackexchange.com/a/140413/18078 and https://diy.stackexchange.com/a/215342/18078 – Ecnerwal May 02 '22 at 19:34
