I have a Nest Learning Thermostat (3rd generation) controlling the one zone of heating in my house and one zone of air conditioning, with red (Rh)/white (W1) wires coming from the boiler system and red (Rc), yellow (Y - cooling), green (G - fan), blue (C), orange (disconnected), black (disconnected), and white (disconnected) wires coming from the air handler for the air conditioning system. This thermostat has its blue wire inserted into its C port, but it reported that it was getting no power from the C-Wire.
Asked
Active
Viewed 1,043 times
Turns out I had blown the 3-amp fuse in the air handler when installing the thermostat (I crossed some wires).
In case it helps someone in the future, the printed figure at the top is a 3 to indicate its amperage rating, not an "E" like I first thought :).
Nigel Stackhouse
- 173
- 7
1For future readers - this is why its important to turn off power to your HVAC before working on the thermostat wiring. The thermostat voltage is low enough that it won't shock you so many people don't turn off the power, but one slip of a wire or screwdriver will hopefully cause a blown fuse that you now have to locate and replace. Worst case, the fuse doesn't blow and the control board is damaged. – JPhi1618 May 06 '22 at 15:13
1And don't just trust your circuit breaker! I had turned off all circuits labeled "A/C" and "furnace" and anything else that looked similar, but that air handler was on a different circuit I guess. There was a switch on the unit that turned off power to it. I should have checked that first (but it was in the attic and there were snake skins nearby and I was a chicken)! – Nigel Stackhouse May 06 '22 at 15:17
1Good point, those breakers should have cut power to the thermostat, but sometimes the 24v section of the furnace ends up getting wired into a general lighting circuit nearby. A switch in the attic should always be provided as a "service disconnect" per code, so at least you do have that. – JPhi1618 May 06 '22 at 15:20
