13
What is the difference between a framing hammer and a claw hammer? Can they be used interchangeably?
Aarthi
  • 1,143
Ed.T
  • 853
  • According to [Dexter](http://en.wikipedia.org/wiki/Dexter_(TV_series)), a framing hammer is a very good method of being caught if you're a serial killer. – Mark Henderson Jul 21 '10 at 22:40
  • I've always heart them referred to as Framing Hammer and Finish Hammer. Both have claws for drawing nails. Major difference: Framing has waffle face on head and heavy weight vs Finish with lighter weight and smooth face so you don't scar your work. Finish may have more curve on the claw. – Fiasco Labs Apr 11 '15 at 05:23
As others have said, a framing hammer is a specialty claw hammer.
So what makes it different? First, weight. A framing hammer is typically 20-32 oz, compared with 10-16 oz for a "normal" household claw hammer. That helps it pound large nails in only a few blows. Related to that is the much longer handle on a framing hammer.
Second is the face of the head: it's waffled to prevent slipping off the nail head, helping prevent bent nails. A regular claw hammer will sometimes have a textured face but not nearly as pronounced, and the face may also be smooth. A regular claw hammer often also has a domed face to allow a skilled hand to sink a nail below the surface with minimal surface damage: that's a feature you won't see on a framing hammer.
Third, the claw is straight since it is optimized for prying boards apart. A regular claw hammer is optimized for pulling nails.
If you're only building a garage, I'd recommend using your regular hammer rather than buying a framing hammer. (Or best of all, just go rent a nail gun!). For inexperienced carpenters, the time spent hammering will probably not be what slows you down. Also, the framing hammer is tiring enough that after a couple hours you may actually be faster with a smaller, regular claw hammer.
If you do get a framing hammer I recommend a lighter one. You'll work faster when you use it, you won't lose much power over a heavier hammer, and you'll feel much better on the second day. In 2010 if you hammer enough that a 32oz hammer makes a difference versus a 24oz hammer, you have a nail gun anyhow.
Rod Fitzsimmons Frey
  • 2,652
  • You can buy regular hammers with a straight claw. – Brad Gilbert Jul 24 '10 at 04:59
    personally, I like a 28oz framing hammer for anything except finish work .. but I've also used one for a long time and hate the toy-ishness that lighter hammers have (when compared to what I'm used to) – warren Jul 28 '10 at 19:47
  • Also be aware that a cut in the forehead is very common when getting used to the straight claw and longer handle! – Kris Jul 16 '20 at 02:54
In my experience, framing hammers are generally larger and heavier, have a straighter "claw" and are more suited to the demands of framing. They provide less accuracy but more force, which is nice. And the straighter claw is good for prying boards apart. If you only have one hammer, you want a claw, but if you are doing a lot of framing, a framing hammer is a nice addition.
Rob Napier
  • 762
Framing hammers are heavy duty rip hammers with a straight claw:
Standard hammers have a curved claw:
Weight and means of manufacture have nothing to do with the differences in versatility of these two hammers. Notice the juxtaposition of both of those, in both these examples, compared to the other answer's requirements; these are just a crappy rip hammer and a (very nice) standard one.
Length, weight and tang are key factors but I prefer rip hammers that can double as a crowbar, over every other consideration. It's not the size...
Mazura
  • 13,357
  • 56
Framing hammers typically have heavier heads and longer handles, and the face is usually not flat (I think the claw is less curved as well).
Framing hammers are a specific type of claw hammer.
They often have a textured head, which will reduce the liklihood of skipping off the nail, but will almost guarantee that you mar the wood that you're nailing into. It can also result in the nail being driven a little bit below the wood. As such, it's really not useful for finish work.
They also tend to be larger, to help reduce the amount of swings needed to get the nail in (they're really not intended for delicate work), and have a straigher claw to get between two laminated timbers to pull them apart.
If you're only going to buy one -- get a general claw hammer, but I'd recommend using some sandpaper to rough up the face if it's polished smooth.
Joe
  • 7,256
  • 47
