Have read many posts on this subject with conflicting information, so help please. I have an older 250W to 12vAC outdoor landscape transformer powering 8 fixtures with 20W halogen MR11 bulbs. I want to replace the 20W halogens with 3W non-dimmable LEDs. My questions:
  1. Will I see flickering of the LEDs due to the lower wattage (160W Halogen .vs. 24W LED)? Some say yes, some say no. What is the real answer?
  2. Do I need to replace the transformer with one that is LED compatible?
  3. Anything else to consider?
Thanks in advance.
JACK
  • 78,739
  • 72
  • 188
TomO
The reason there are conflicting reports is because there are so many different types of LEDs. Some require an external DC voltage source, some can use an external AC source. I've used a number of different manufacturers and have not had any flickering problems due to low wattage of a landscape transformer as long as that wattage exceeded the total wattage of the bulbs. Just make sure you get LED bulbs that use an AC external source. The core losses from your 260 watt transformer only being utilized for 24 watts will eat away some of the savings from switching to LED bulbs but the cost of a new transformer has gone up quite a bit so it's a judgement call. you might want to get higher wattage LED bulbs since the transformer will handle it. I started out with 2 watt bulbs and have since moved up to 5 watt bulbs in my front and back yards
JACK
  • 78,739
  • 72
  • 188
    It is true the transformer has nothing to do with flickering it is the junk from an import company that causes the problems get DLC approved LED’s and there won’t be a problem, note these cause more as they are not the cheapest junk to import – Ed Beal May 28 '22 at 01:13
  • Thanks to all who replied, but Ed, your comment is now causing things to make sense because among other places, it was one of the Chinese imported bulbs for sale on Amazon that mentions flickering might occur. And if it did, just use a couple of halogen bulbs in the wire run. Right! That makes a lot of sense when replacing halogens. At least they admitted they were junk. Thanks again. – TomO May 29 '22 at 20:08
  • Jack, any chance you could comment on this. Past my pay grade: The core losses from your 260 watt transformer only being utilized for 24 watts will eat away some of the savings from switching to LED bulbs – TomO May 29 '22 at 20:10
  • @TomO You're paying for the transformer to be energized even when there is no load on it. Just like your phone and laptop chargers, if you keep them plugged into the wall socket when nothing is being charged, they're still using electricity. Your 250 W transformer probably used 2.5 to 5 Watts just to energize it. Those are the core losses. So that's 1 to 2 bulbs worth of electricity that you don't get. It's always good to switch off the lights by switching the primary voltage instead of the secondary voltage. We're only talking about 6 bucks a year so don't rush out and get a smaller tx. – JACK May 29 '22 at 22:32
  • Understand, Tks! – TomO May 30 '22 at 15:42
With dimming you have all kinds of potential issues. But without dimming, all you should need to do is match:
  • Voltage (many light fixtures can take a wide range of voltages, some have a very narrow range)
  • Current (the total of all the light fixtures has to be <= the maximum output of the transformer or circuit source)
  • AC vs. DC
Typically lights will be high voltage (e.g., 120V or 240V) or low voltage (e.g., 12V or 24V). But with LEDs things get a bit tricky. Because LEDs don't run on AC (technically if the voltage is right, you could run an LED directly from AC, but it would only make proper use of incoming power in half of each cycle), they have drivers which convert the incoming power to a proper low voltage and DC. A traditional transformer changes the voltage but keeps it AC.
So you really have two practical options. The third, impractical option, is to use 120V or 240V LEDs (which are really LEDs with drivers to convert 120V/240V AC to low voltage DC), but that would mean bringing 120V or 240V power into your landscaping, which is potentially very dangerous. Low voltage wiring has very few rules because it is relatively safe. It is quite likely that the existing wiring would not meet code for use with 120V power.
  1. Existing Transformer - Keep the existing transformer and find matching LEDs - i.e., MR11 base, compatible with 12V AC power. Don't worry about current - the LEDs will use less than the halogens and that should not cause any problems.
  2. New Transformer or Power Pack - Replace the existing transformer with a new transformer (but a different voltage matching the LEDs you find) or a power pack ("wall wart") to convert from 120V or 240V AC to low voltage DC, to match new LEDs that are compatible with the specific DC voltage. If those LEDs use an MR11 base, great. If not, you will need to replace the bases to match the LEDs, or hardwire the LEDs. Keep in mind that good quality LEDs should last significantly longer than halogen bulbs, so replacement should be in the range of several years rather than several months.
  • This sounds good on the surface but there are many 6,12&24 volt ac/dc lamps out there and if it had any other kind of lamp yes any other an led will not load the transformer so that is not a problem at all. – Ed Beal May 28 '22 at 01:19
    You say, in your 3rd to the last paragraph that "but that would mean bringing 120V or 240V power into your landscaping, which is not a good idea for safety reasons." Way to soft on that. IT'S dangerous! buried wiring for low voltage landscape lighting has practically no code requirements bc LV is generally considered safe, regardless of what happens. Line voltage buried wires have strict code requirements regarding depth of bury, protection, etc. Not only that, LV cable doesn't have the proper insulation for line voltage. – George Anderson May 28 '22 at 13:56
