I found this tool in the middle of the road. Appears to be a pry bar of some sort, approximately 16" long. Can anyone identify it and its use?
Asked
Active
Viewed 3,701 times
39
HandyHowie
- 1,413
- 9
- 12
18
10Someone is lucky that a forgotten tool from a careless mechanic didn't block his steering. – fraxinus Jun 07 '22 at 14:46
11Also known as a Ball Joint Destroyer. Separate a ball joint with this - yes. It's what it's designed for. But you aren't using that ball joint again for anything. In most cases that's fine, but occasionally you just want to get the ball joint out of the way for a few minutes, in which case, there are better tools for the job. – PeteCon Jun 07 '22 at 18:56
@PeteCon these things work better in pairs, with the two sloped planes pressing against each other. Access can be an issue. – Criggie Jun 08 '22 at 23:13
