I'm kind of in an inbetween land right now where I can't determine if I have an ant infestation or not.
Every morning when I leave for work I find half a dozen dead winged ants near my front door. They are never more than 1-2 feet away from the door. I clean them up and dispose of them but the next morning more appear in the same area. always approx. half a dozen. Never more than 7-8 (always dead). This door is directly connected to the outside of the house. The obvious assumption is that they are coming in from outside but I checked meticulously for cracks and there were none, but as with insects I understand they can squeeze in through the smallest places. Although I desperately wish this was the case, I am a pessimist by nature so I think of worse and worse situations. The next being...
But then question arises - why are they dead. Well a quick online search discovers that these kind of ants will die after mating. So if they're mating and then dying, does that mean their bodies are being discarded by their brethren from somewhere inside the house? So I looked online some more - and these guides outlined very general points for an infestation. The clearest point being, "If I have a bunch of dead ants located in an area" then I most likely have an infestation.
But how much is a "bunch" is it 6 dead flying ants? or is it 50 dead flying ants. or is it 100+?
So I take this question to this group - is there a method I can use to somehow determine if I have an infestation or are these ants just kinda flying their way in through small cracks and then dropping dead in the front door?
RtxTrillihin
  • 101
    Did you ever here of a stakeout? – JACK Jun 21 '22 at 20:14
    My understanding is once they have wings, it means the nest is mature and they're looking to expand. So you may have a monster sized nest nearby and not know it. It's way too much of a coincidence to keep finding them in the same place. I agree with @JACK .... Get a 6-pack, a small TV, and just sit and watch for a while. They won't mind you being there. It'll be boring but the 6-pack will help ;) – Kyle B Jun 21 '22 at 20:25
  • Ah yes, the long game. If I was rich I was also thinking of setting up a comprehensive camera system with point by point camera zoom and movement detection – RtxTrillihin Jun 21 '22 at 20:25
  • the thing that should really concern you is that they are dead ... whatever is killing the ants may also be harmful to humans – jsotola Jun 21 '22 at 20:27
    Are you sure they’re ants and not termites? Pic? Anyway dead winged ants are probably males. The female winged ants will mate then land somewhere and look for a spot to set up a new nest and then lose their wings and become queens. It’s also possible that someone has sprayed poison in a location that crosses their path out of a nest and as they leave the nest they get poisoned and happen to die near your door. – RibaldEddie Jun 21 '22 at 20:37
  • Winged ants could be Termite. – asinine Jun 21 '22 at 21:22
  • Is there a light near the door that could be attracting them? Are there any open windows with bad screens near the door? – Steve Wellens Jun 22 '22 at 04:44
Let's determine what they are, since the treatment will differ.
Ants would be harmless, while Termites can create serious damage to your home.
Ants need food source (left overs and spills)
Termites use your home as food.
But before you freak out, Termites are usually not out in the open, only once per year when they propagate (expand to new home).
If it is an Ant, those are FLAYING MALES following the Queen to mate. Here are two possibilities. You have an Ant nest somewhere near outside, and few get lost in the confusion. The other is you have a Queen inside your home starting a nest.
The treatment will depend on what they are.
asinine
  • 16,852
  • Some ants are not harmless. Carpenter ants will damage the structure of your wood frame home. They can also be audible inside as they scrabble around in your house framing. That’s one unfortunate way to discover a nest, as I have experienced first hand. – RibaldEddie Jun 21 '22 at 23:19
    This is a comment, not an answer. – gnicko Jun 22 '22 at 03:27
  • @gnicko how so, it is a full flagged answer, thanks for nothing and downvote – asinine Jun 22 '22 at 03:41
    You say: _"Let's determine what they are, since the treatment will differ."_... Once you use comments to determine the details necessary to answer the question (e.g. what they are) write up a proper answer to the original question which was "how to determine if there is an infestation" and I'll take back the downvote. – gnicko Jun 22 '22 at 03:50
  • @gnicko correct, but I can not post pictures in comments, to help OP identify them. The answer is incomplete to the point how to eradicate them. The OP question was how to identify them. – asinine Jun 22 '22 at 03:57
    @knowitall Are we reading the same question? While it would make a difference with how to eradicate the bugs, there is no "how to identify" in the original question: _"is there a method I can use to somehow determine if I have an infestation or are these ants just kinda flying their way in through small cracks and then dropping dead in the front door?"_ You're on the right track, but this is not an answer. It is a comment seeking clarification. – gnicko Jun 22 '22 at 12:22
  • @gnicko I do not see you providing a answer – asinine Jun 22 '22 at 18:58
  • @knowitall: Nope. I don't know much about bugs, or how they congregate, etc. – gnicko Jun 22 '22 at 23:23
  • @gnicko but you know enough to criticize my answer – asinine Jun 22 '22 at 23:30
  • @gnicko the OP question: Is there a surefire method to determine if I have an ant infestation? for that one has to give the OP. a method to identify the ants. – asinine Jun 22 '22 at 23:45
  • Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/137277/discussion-between-gnicko-and-knowitall). – gnicko Jun 22 '22 at 23:51
