16
We're switching out the natural gas oven for a new model, and we opted for electric. We already have the 240v supply in place and ready to go.
The oven is the last piece of natural gas equipment in our home. We still have pipes running about for the water heater (which we recently switched out for electric, and capped off).
Since there will still be natural gas pipes running throughout the house, are there any special considerations we should take as we cap-off the final leg in our gas system, and shut it off at the meter?
I.E. since there are pipes about, should I somehow evacuate whatever leftover gas is in the lines of the house? Should I take the pipes out? I'm just unsure if there's anything I'm "missing" besides just shutting off the gas at the main (and calling to cancel the gas service)
Tyler M
  • 1,070
  • 25
    Induction is supposed to be as good as gas, if not better, with a few exceptions (such as using a wok). And that (@Elcan) couples heat more efficiently into the pan than gas, offsetting the transmission losses. Gas has transmission losses too though, in the energy used to pump it around, compress it, etc. And very few places have no renewable generation; most are increasing. If I get solar panels as I hope to, I'd seriously consider going for a combination of induction and halogen electric burners – Chris H Jun 29 '22 at 08:25
    @Martha I recently switched from Gas to Induction, and it's absolutely amazing. Temperature control is just as good, and induction is a lot faster when you need it. So even apart from climate change or not wanting to support Putin (if you're in Europe) etc, it's just a better cooking experience. But I agree that a standard electrical stovetop would be a step back. – Eike Pierstorff Jun 29 '22 at 11:14
    @njzk2 I've heard of it. I've heard of Valhalla too. Good fiction. – paulj Jun 29 '22 at 11:17
    Ask California about rolling brown outs and their push to have _everything_ electric. See how that's going there... – FreeMan Jun 29 '22 at 11:47
    @Eclan electrical generation from gas is done very efficiently at the power-plant scale - much more so than the efficiency of a stovetop burner. There are also air quality and fire safety considerations to be made. – Ari Cooper-Davis Jun 29 '22 at 11:49
  • @njzk2 Gas stove is so much more efficient than electric one though... It only makes sense to replace it with fully electric one in countries with at least 70% electricity coming from renewables IMHO. Otherwise, I would say you are actually harming the planet. – Firzen Jun 29 '22 at 14:37
    To put this entire comment section to rest: I'm switching from Gas to Induction because I don't want my toddler turning on the gas. Not a lot he can do to hurt himself with induction. – Tyler M Jun 29 '22 at 14:46
    @FreeMan but then you also need to ask them about the years-long drought that they are suffering, and see what is the lesser evil in the long term – njzk2 Jun 29 '22 at 19:19
    @njzk2, I love all the electrical work, of corse I am a electrician but the country will not have the electrical infrastructure to change to all electric for 20-30 years or more and if we get a good solar flair the grid will go down hard because it has not been “hardened” and this has been known for 50+ years so what is the lesser of 2 evils? But this is off topic as is your comment. – Ed Beal Jun 30 '22 at 08:56
I would not take the pipes out because of the demo cost and the fact that having them available may increase the value of the home for resale. Call the gas utility and have the service turned off and when they pull the meter cap that line and there is no more real safety issues but the line should be capped to prevent additional moisture and rust inside the lines.
    I would intentionally air out the pipes after the service has been shut off, but apart from that yeah, 0 reasons to remove them – Hobbamok Jun 28 '22 at 08:24
    Isn't airing them counter-productive? There is no pressure to force the gas out so no significant fire danger, on the other hand, air brings inside moisture and oxygen (=corrosion) and mixing gas and air is a risk in itself. @Hobbamok – fraxinus Jun 28 '22 at 09:04
    @fraxinus would the gas leak out and oxygen leak in over time anyway? – user253751 Jun 28 '22 at 11:56
    It shouldn't. And if it does, it will hardly reach explosive ratio outside at any point of time (inside is rather hard to have a spark) – fraxinus Jun 28 '22 at 13:10
    @fraxinus, I'd think that having pipes filled with even a small amount of gas during a structure fire would pose a problem. I'm not sure how much, though. It likely wouldn't be the largest problem at that point, but it might make some things worse. The pipes could be vacated during a dry period, like the middle of winter, when moisture is at the minimum, and the OP could use a compressor with a moisture cup at one end blowing the gas out the other to also help reduce moisture. – computercarguy Jun 28 '22 at 20:08
    I would think that the pipes in the house would air out when the meter is pulled. Even if capped shortly there after. – DaveM Jun 28 '22 at 22:43
    @computercarguy there is a trivial amount of gas in the pipes. I might be more concerned about drapes, bedding, carpeting, clothes in closets, boxes of matches... – Technophile Jun 28 '22 at 23:06
  • I would be more worried about a box of matches or a bic lighter in the case of a structure fire. there is not much explosive power in the gas line and could air get in I would say no way as both are at atmospheric pressure. Note Air is only ~21 oxygen @user253751 for natural gas to be flammable it has to have the correct mix with air or 10% +- 5 is the range natural gas is flammable below 5 not enough to burn above 15 two much. – Ed Beal Jun 29 '22 at 04:06
It's not terribly difficult, just open a few ends of pipe and consider it evacuated after about an hour. Make sure you have plenty of ventilation as well. Cap it off again to avoid rusting the inside of the pipe.
There is very little gas inside of the pipe; it's usually pressured to just .25 PSI. There is no practical danger of leaving it inside the pipe if you're shutting it off at the meter. Over time it will leak through the joints anyways.
If you evacuate it then your basement will smell like mercaptan for a few days.
That's up to you.
A reciprocating saw with a carbide-tooth blade makes light work of gas pipe. Just be careful not to cause collateral damage!
Pros:
  • Makes the basement neater
  • Makes room for other utilities
  • Get some pocket change at the scrapyard for your pipe
Cons:
  • It takes effort
  • If you ever had a need for gas in the future then adding lines would be costly
  • If you're selling your home then buyers might see it as a negative; I know I would
MonkeyZeus
  • 16,461
  • 59
  • I had my gas supply disconnected (meter removed) at a house which I am demolishing in France. There was absolutely no smell of gas on opening the tap to the heating boiler and I cut out all the gas pipework with an angle grinder without any problems (admittedly, the boiler hadn't been used for 10 years). – grahamj42 Jun 29 '22 at 11:37
  • @grahamj42 Sounds like either France doesn't use an odorant such as mercaptan or the pipes have been in disuse long enough for things to dissipate. – MonkeyZeus Jun 29 '22 at 11:54
  • I'm pretty good at detecting mercaptan, so I think it was the latter. – grahamj42 Jun 29 '22 at 13:46
  • @grahamj42 Same here. Sometimes my wife will bump the stove knobs and not notice a thing for well over an hour. Me, I can smell a leaky joint in a 1,000 square foot basement. – MonkeyZeus Jun 29 '22 at 14:03
Shut off at the meter is the main thing. Cap off the pipe. There should be a service valve on the cooker supply pipe already in the shut-off position.
There's no reason to worry about the small amounts of gas still in the pipes.
To further reduce the chance of a gas leak leading to disaster after some idiot(*) turns the meter valve back on, you might lock the meter valve in the off position. Maybe with tape, if it has no provision for a padlock.
Note, when you terminate your gas supply with the utility company, they will probably do this for you, either at (or inside?) the meter, or with an upstream valve outside the property that you don't have any access to.
I'd leave the gas piping in the house in place, in case the next owner of the property wants a gas supply. (I know I would!) If it's actively in the way, it's easily cut and removed.
(*) or a person with early-stage dementia.
nigel222
  • 778
