My sewer line runs through our basement wall to the septic tank. Due to shifting over the years the pipe has broken at the outside of the house. How do you go about removing the cast iron pipe out of the basement wall to replace with PVC?
  • What is the basement wall made of ? concrete ? What is the pipe size ? how far into the home does the cast iron pie goes ? – asinine Jun 30 '22 at 06:31
  • Check this video : https://youtu.be/G-GFxdgMHAQ – asinine Jun 30 '22 at 06:37
    With a hammer and a cold chisel. After you dig a hole outside. If you break the bell off the next pipe that's outside, you use a rubber coupling. If it still has the bell you use a ribbed grommet. – Mazura Jun 30 '22 at 21:43
There are adapters specially made for that.
Example
adapter
You will have to cut the iron pipe, and dig it out the ground.
You will have to feed the PVC pipe through the wall.
A good handyman can do that.
Tim
  • 5,198
asinine
  • 16,852
  • This does not address the question, which is about removing the broken pipe, not coupling the pipes after the broken pipe is removed. – Ecnerwal Jul 02 '22 at 20:12
  • @Ecnerwal maybe your German is not so good. The OP asked "How do you go about removing the cast iron pipe out of the basement wall to replace with PVC? " – asinine Jul 02 '22 at 20:39
