My front porch light fixture is an open bottom fixture hanging on a decorative chain. So there is access to the bulb. But to use a "light bulb changer on a pole" or a DIY plastic bottle on a broomstick - either will easily grab the bottom of the bulb but when turning, it turns the entire chain and fixture. Remedy - install new fixture with easier access? I am a senior lady living alone and cannot get up on a ladder high enough to use both hands to hold the fixture still with one hand and change the bulb with the other. Just moved here and don't know any neighbors. Just can't think of any way to steady the fixture so I can turn the bulb without a tall ladder. Ideas? Thanks in advance.
Deborah
    Time to make new friends. Cookies help. – crip659 Jun 30 '22 at 21:13
    Check with the local stores. They usually have boards with local handy men listed. Asking for a little help is always a great way to meet neighbors... "Can I borrow some sugar?" worked for me many times. – JACK Jun 30 '22 at 21:36
    However you resolve this, whether using a gadget, friends with a ladder or a paid handyman, get the best possible bulb you can. Which would be an LED from a major manufacturer (Cree, Philips, etc.), DLC certified, with a really long warranty. DLC requires a minimum 5 year warranty, but some have even longer. A long warranty is not a guarantee of performance, but it is a good indicator. Not necessarily worth spending an extra $ 5 on every bulb in the house. But for the really hard to change bulbs, it pays in not having to replace as frequently. – manassehkatz-Moving 2 Codidact Jun 30 '22 at 21:37
knowitall has the right idea - you need a short and sharp jolt.
The weight of the bulb is very light. The weight of the fixture is a great deal more. If you turn gently, the bulb and fixture will turn together. If you turn very sharply, the bulb itself will turn before the rest of the fixture. That will turn too, but for an instant, the bulb will turn first. The trick is not to let the slack run out and cause a "snap" in the other direction! Several snaps like that should get it loose.
Assemble another rod/stick of sufficient length to reach an open lower link. Apply to the end of the rod a horizontal pin to pass through the link. While holding this stick in place, turning the bulb changing tool will wrap the chain only slightly, allowing the tool to perform the task.
fred_dot_u
  • 10,721
    and you want a old lady to do this surgery ? – asinine Jul 01 '22 at 00:44
    This is a really bad idea. Asking an elderly woman to put a long stick over 14' into a chain above her. and then to use another long tool to grab the bulb? I've used those myself and I'm a capable 60yo, they are not easy to use. Best bet is to hire a local handy man and like manassehkatz... said get a high quality bulb. To the OP, please don't try this on your own. To Fred, DV for a dangerous answer. – George Anderson Jul 01 '22 at 01:30
  • Apparently this "elderly woman" was able to extend the bulb remover to a height sufficient to discover that the chain would twist while attempting to remove the bulb. Your comment is not productive. – fred_dot_u Jul 01 '22 at 08:45
  • @fred_dot_u I disagree. I think recommending that a senior citizen who self describes unable to climb a ladder enough to reach the fixture, that she not try it, not put per personal safety at risk and get a handyman is good advice. I think it's a very productive comment. – George Anderson Jul 01 '22 at 16:43
  • Another aspect of my question is one that it is helpful to a neighbor who might want to assist. No special tools beyond the bulb remover and a long stick. – fred_dot_u Jul 01 '22 at 20:27
