My house has no apparent main water line shut off valve. Usually one would find a shut off valve right near where the water main entered the house structure. At my current house I have never been able to determine where the water main entry point is located.
I have a house that has a lower level that is on a slab level with my garage. The other 2/3 or the house is built over a crawl space. I have checked the crawl space and found no water line entry points there. It is not possible to see where the water lines are routed in my house because they are all embedded in walls and ceilings that are covered over with drywall. Even my garage area, furnace area, water heater area and laundry room are all finished over with drywall. Thus I have no idea where the source point for my water lines is located.
It is possible the water main comes up through the slab of the lower level of the house and immediately goes up into a wall where it is hidden away from view. It is equally possible that the line enters below ground level at the periphery of the house and not findable unless I decided to dig a deep moat all around my house.
Currently if I want to shut off all the water in my house I have to use a T-bar handle to shut it off by the street near the water meter. This would be a less than ideal situation in the case of a water leak emergency. It is just not feasible to expect family members to be able to find the T-bar handle and run out to the street to turn off the water. For this reason I want to find the water main entry point and install a proper shut-off valve.
I am looking for suggestions about how to go about finding the water main entry point to the house. And hopefully there is a suitable method that works without having to rip down tons of drywall.
* Some Added Comments *
The water meter is out by the street under a concrete cover about six inches from the curb.
The water meter is at the extreme corner of the lot to the side of the driveway away from the house.
The water company's input ends about about six inches over the edge of the curb!!
The house was built in ~1987.
* UPDATE * I have found the water main entry point!! This was located a few weeks ago when I replaced some iron pipe risers out of the top of the water heater that had corroded so bad that a small leak had started. The gas fired water heater sits in the back corner of an alcove off the side of the garage. (The forced air furnace is also in this alcove). As you can imagine it is a rather tight fit in this alcove. I found that the water main is a 3/4" copper pipe that comes up through the concrete slab floor under the rear part of the water heater. It has an immediate 90 degree elbow that aims the water line toward an inside wall where it pokes into the wall through drywall.
Here is a rough diagram of the layout.
I will be working at opening the wall behind the water heater and installing a shut off valve there. Unfortunately it has to wait till a day when I can stay home from work and have the city utility folks come out and shut off the water main. I tried to shut off the water main with my T-bar handle but something is clearly wrong with the valve because it does not turn the water off when rotated either direction. I was able to move the valve through 90 degrees of rotation but no luck stopping the flow of the water.
Michael Karas
  • 64,093
  • 63
  • 142
    How old is your home? It should be a straight line from the streetside shut-off to your home and enter through the nearest foundation wall. That at least narrows the search a bit. Are your floor joists above the crawlspace insulated? – ryanwinchester Feb 14 '13 at 07:46
    Maybe you could call the folks @ http://www.digsafelyoregon.com/index.asp and tell them you want to dig up your yard for landscaping. They could locate all your utilities. – ryanwinchester Feb 14 '13 at 08:00
    Do you know where the water meter is? – shirlock homes Feb 14 '13 at 09:34
    It's entirely possible that somebody walled it up. People do things like that all the time, especially since water meters and shutoff valves are not the prettiest things to look at. Shirlock is right though, if you find the meter, you'll find the entry point. – Tester101 Feb 14 '13 at 12:09
    Since the water company owns the meter, they "should" know where it is. Ask them. – shirlock homes Feb 14 '13 at 12:27
  • I've added some more comments to the question to respond to the above comments. – Michael Karas Feb 14 '13 at 13:14
  • There's a good chance the shutoff will be near the water heater. The entry point will likely come through the slab into a heated part of your home, rather than through an unheated crawlspace where the pipe could freeze. – BMitch Feb 14 '13 at 14:08
  • @BMitch - No such luck. The water heater does have its own shutoff valves but the water pipes feeding to/from the heater come from inside a inner wall. If the entry pipe comes up through the slab it must do so directly under a wall someplace. – Michael Karas Feb 14 '13 at 14:27
  • If other homes in your neighborhood were built around the same time, you may get some clues from a neighbor whose line is not concealed. – TomG Feb 16 '13 at 02:00
  • @TomG - I agree with your comment. I mentioned the same thing earlier on a comment under Tester101 's answer. I should see some neighbors around this weekend if it is nice outside. – Michael Karas Feb 16 '13 at 03:40
  • It seems that a T-bar shutoff tool hanging in the garage (or other convenient place) with a hand drawn map (maybe even laminated) showing where the shutoff is located is a perfectly acceptable solution. Seems no worse than a shutoff valve that's so hard to find that you can't find it (assuming that it exists at all) – Johnny Mar 02 '15 at 18:04
  • The shutoff at the meter on my home requires a full 180 turn for shut off. – diceless Mar 03 '15 at 04:22
    @diceless - I tried turning the street shutoff more than 90 degrees and the whole valve body was seeming to want to twist. Last thing I wanted was to break the thing so I left off and will wait till the city can send some folks out who can take responsibility if the thing breaks or needs replacement. – Michael Karas Mar 03 '15 at 04:25
Everybody wants to save money
Builders and utility companies are not in the business of wasting money, which means the main line will be as straight and as short as possible. This is a big help to you, since it will narrow your search. Walk out to the curb shut off, and look back at your house. Try to determine the straightest, shortest path between the curb shutoff and the house. Now you'll have a general idea of where the line enters the home.
Trace the line
In most cases utilities bury a tracer wire in the trench above utility lines, to make the lines are easier to locate later. If you call 811 (assuming you are in the US, though I believe this service is offered in other areas as well), they should be able to send somebody out to locate the line for you. This will show you the approximate path the line takes to the house.
Don't let pipes freeze
Because it's a water line, it will likely enter your house below the frost line. If you can determine the frost depth in your area, you'll have a more targeted area to search.
People are idiots
It's not uncommon for people to do dumb things, especially when they don't know how dumb they are. Water meters and shutoffs are ugly, and nobody wants them in their newly remodeled living space. It's possible that your valve has been walled up, and you'll have to remove some finish material to find it. Look in closets, and keep an eye out for access panels.
If only you had X-ray eyes
There are a few tools that can help you search a wall where you suspect the valve might be. A stud finder should be able to locate pipes in the walls, depending on the stud finder you buy. A metal detector will find anything metal, so that could also come in handy. If you've got a bunch of cash to throw around, a thermal camera may be able to actually see the pipe through the wall.
Where does service enter?
After reading the update to the question, and then reading through building code. It seems that it may be possible that there is not a shutoff valve where the line enters the building.
International Residential Code 2009
P2903.9.1 Service valve. Each dwelling unit shall be provided with an accessible main shutoff valve near the entrance of the water service. The valve shall be of a full-open type having nominal restriction to flow, with provision for drainage such as a bleed orifice or installation of a separate drain valve. Additionally, the water service shall be valved at the curb or property line in accordance with local requirements.
According to this, there must be a shutoff valve "near the entrance of the service". However, in most cases the water meter has to be near the "entrance of the service" too. In your case, it may be that the "entrance of the service" is at the property line, and not at the building. So there may actually be no shutoff valve inside the house.
  • After your comments I can make a pretty good guess where the water entry may be. I agree that the line will be deeper in the ground. Here in Oregon in the "valley" area it does not freeze too much so its possible that the line is not very deep. After all the water meter and street shutoff valve are located in a small "well" with a concrete cover that is all of eight inches deep. – Michael Karas Feb 14 '13 at 13:26
  • Good point. I'll make it a task to ask the neighbors around here if they have shutoff valves. All the houses were built at the same time in similar conditions. – Michael Karas Feb 14 '13 at 14:30
    Another thing to look for is a sewer clean-out. At least in my house, the sewer and water line are right next to each other. – Steven Feb 14 '13 at 18:26
  • The frost depth in Oregon ranges from around 5-20 inches from the coast inwards. I'd guess you're closer to the 5 :P – ryanwinchester Feb 14 '13 at 21:18
Try looking around your water heater. My home was built in Georgia red clay in 1969/70 on a concrete slab and the water cut off valve is on the back wall of the house about a foot or so from the water heater VERY close to the floor. The handle for the valve, in my case, sits to the side so all you see is the side view of the handle. The washing machine hookup is to the left of that handle. I would say look for these items and you'll find your cut off valve.
And yes they should be in a straight line from the street meter since the pipes used to pump the water in and out aren't prone to convenient curving.
Also if you think about it, unless the floor plans have been drastically remodeled, the usual place to locate and install a water cut off valve would be where you would be using a water heater and a washer, hopefully both in the same area of the house.
One more thing, look for a blue handle for the water cut off valve...and if you ever have to replace it....use a blue one! Blue for cold water! ;-)
...hope this help!
Susan
You can use 2 coat hangers to find the water line. See the videos here. Thanks
https://www.youtube.com/watch?v=AW_xDXDtDmc
https://www.youtube.com/watch?v=Ik6lAkzVEQs
  • Can you summarize the videos, in case the links break for whatever reason? – ThreePhaseEel Feb 24 '18 at 19:15
    Dowsing rods don't really work. – fixer1234 Feb 25 '18 at 02:12
  • James Randi would like a word. https://upload.wikimedia.org/wikipedia/commons/thumb/f/f5/Preferred_official_head-shot_from_James_Randi_Educational_Foundation.jpg/440px-Preferred_official_head-shot_from_James_Randi_Educational_Foundation.jpg – bshacklett Mar 22 '23 at 13:40
