An article from my AARP magazine suggests using a toaster oven vs a regular full size electric oven to bake a pizza, make a dinner, bake a pie, etc because it would use about half of the electricity so save on the electric bill. Problem is, The toaster oven draws 14 amps in the bake mode and my oven draws only 12 amps per leg (220) while the elements are on. How do they suggest that I will cut the electric power in half when the full size oven uses 2 amps less than the small 120 volt toaster oven?
4The Toaster is more efficient in this case. It is probably 1/4 size of the oven. And size matters. The smaller are heats up faster. – asinine Jul 17 '22 at 04:08
With some exceptions (208V in some areas), US/Canada electricity is 'x' and '2x'. That has evolved over time from 110/220 to 115/230 to 120/240, and in fact the actual supply can be a little higher or lower - but always 'x' and '2x'. – manassehkatz-Moving 2 Codidact Jul 17 '22 at 04:14
2One more comment. Toaster ovens are very old school at this point. My wife & I just got an air fryer (Ninja) that we love. You can do anything with it from toasting bread/bagels to frying chicken or steaks. We tossed our old toaster bc he Ninja t did such a much better job toasting. I think it's pretty efficient too since it doesn't put out too much heat that would need to be cooled be A/C – George Anderson Jul 17 '22 at 04:26
25Put a power consumption meter on it and you can get the real facts - not just some hypothetical answers with no real quantifying details. The surest way is a power consumption monitor. – Ken Jul 17 '22 at 08:06
1@GeorgeAnderson Where I live, electricity is about 50ct/kWh, and my full-size oven is painfully slow at heating up. I don't have a smaller oven that will fit a pizza, but my estimates for heating up something small like chicken nuggets in my table-top contact grill versus the oven suggest a difference of over 50 cents per usage, which starts to add up. Don't assume everyone's situation is exactly like yours. – marcelm Jul 17 '22 at 13:55
3@marcelm But I think that is exactly the point. A general article/blog/etc. should not be making assumptions either. There are tremendous differences depending on electricity pricing (and, if you have some appliances that use electricity and some that use gas then gas pricing as well), appliance design, appliance installation (an oven inside a brick wall is different from an oven in a wood cabinet), etc. Blanket statements "toaster oven will cut your cost in half" are rarely valid when you start looking at the details. – manassehkatz-Moving 2 Codidact Jul 17 '22 at 15:31
1@manassehkatz-Moving2Codidact Fair enough, I agree with the blanket statements being bad. But that's also what George was doing, to an extent; he took some numbers, concluded it's not worth it, and advised _"Folks, let's face on the big stuff, not whether your should bake a pizza in a toaster oven or regular oven."_. I disagree with that conclusion, I think it's good people are thinking about this, and I encourage them to measure things for themselves! No, baking pizza in toaster ovens won't solve the world's energy problems, but in some situations small things like that can make a difference. – marcelm Jul 17 '22 at 15:58
You should make it clearer that the oven is connected to 220 (or, probably, rather 230) Volt. – Peter - Reinstate Monica Jul 18 '22 at 15:20
1@Peter-ReinstateMonica In US/Canada, the "big" voltage is usually exactly double the "small" voltage, so 120 -> 240, not 220 or 230. Only exception is 2 legs of 3 phase = 120 -> 208. – manassehkatz-Moving 2 Codidact Jul 18 '22 at 16:07
The actual power consumption is Watts, not Amps. Watts, for a resistive load such as an oven (toaster or full-size, but not microwave) is essentially Volts x Amps. So the comparison is really:
- Toaster = 120V x 14A = 1,680 Watts
- Full-Size Oven = 240V x 12A = 2,880 Watts
If they take the same amount of time, and if they both run at full power levels the entire time, then the toaster oven will use approximately 58% as much as electricity as the full-size oven. Not exactly 1/2, but pretty close.
There are a few other things to consider:
- If you use an oven for more than a few minutes then it will cycle on/off to maintain the set temperature. If the toaster runs at a 75% duty cycle and the regular oven at a 50% duty cycle then the toaster will use 87% as much power as the full-size oven. If the toaster runs at a 50% duty cycle and the full-size oven runs at a 75% duty cycle then the toaster will use 39% as much power as the full-size oven. etc.
- Baking Time - In theory any two ovens that can maintain the desired temperature should take about the same time to bake a given item. However, the time to get to the desired temperature (preheat) may vary significantly between ovens.
- Insulation - A modern full-size oven should be well insulated, so that relatively little of the heat gets into the kitchen, although obviously all the residual heat after baking is done will eventually get into the kitchen. But good insulation and design will mean the oven can keep the heat inside better, both lowering the duty cycle and lowering the amount of energy wasted heating up your kitchen. In the winter this is not necessarily a problem, but in the summer any extra heat will either make the kitchen more uncomfortable or increase your air conditioning load. Toaster ovens typically have very poor insulation.
The specifics will vary a lot depending on the specific ovens. But in general I would expect a toaster oven to be more efficient on the small stuff (e.g., making toast, reheating pizza, etc.) where the duty cycle on any oven will likely be 100% and where the overall time of use means the extra heat from a poorly insulated oven will not have that much of an effect on the kitchen. But on the big stuff (e.g., baking a pie) the duty cycle will likely favor the big oven and the overall time plus variation in insulation (full-size oven normally being significantly better than toaster oven) will favor the full-size oven.
And unless you are running a bakery, most of your energy costs are likely to be:
- HVAC
- Water Heating
- Lighting (though less than it used to be thanks to LEDs, can still be significant if lights are on a large part of the time)
with cooking generally one of the smaller components with large intermittent usage (peak demand) but low total cost.
Update: After some interesting and thoughtful comments, I looked a little more. While everyone's individual home usage will vary depending on age of home, type of appliances, sources of energy, weather, etc., a rough guide from the U.S. Energy Information Administration (EIA) has the top residential electricity uses as:
- Air Conditioning 17%
- Space Heating 15%
- Water Heating 14%
(In terms of total energy usage, space heating and water heating are probably much higher because many homes use natural gas or other fossil fuels.)
Lighting is next at 10%, though that was a 2015 number so I am sure it has been decreasing thanks to the rapid adoption of LED lighting.
Cooking is way down on the list at 1.4%, lower than refrigerators, TVs and some other things. Even if you combine microwaves, cooking is only 2.5% of the total, and you can't use microwaves (practically) to bake a pizza.
So if you can save 50% on electricity use with a toaster oven compared to a full-size oven (of which I am dubious in general, but each situation will vary), for most people it will not be large enough to be practical for everything (chicken nuggets, OK; Thanksgiving turkey, not so much), and it is only part of "cooking" (there is also the stove top for boiling, frying, etc.). So only a small part of the 1.4% will be saved, and likely at some inconvenience as well, depending on usage.
Yes, every little bit helps. But if you still have incandescent bulbs, replace them (immediate easy savings). If you have old HVAC equipment, consider replacement (not so easy and significant up-front cost, but huge long-term energy savings).
- 105,505
- 9
- 125
- 304
7Great, thorough answer! I slightly disagree with you on one point: Lighting, with LEDs so efficient now, I don't believe lighting is a major draw. If they are still running incandescent, yeah, I agree. I think, not sure, but believe that electronics that are on 24/7 are a significant draw: Desktop PCs, Cable boxes, routers and modems, streaming boxes, security systems and so forth. HVAC & DHW heating are certainly big draws. – George Anderson Jul 17 '22 at 11:21
4Great answer. To add to you last part about energy costs and appliances, I’m doing a tiny house and am surprised how much total energy the fridge uses! Low amp draw, but 24hr usage unlike stoves and on demand water heaters. – mark f Jul 17 '22 at 16:12
@GeorgeAnderson Networking hardware and embedded devices tend to not be as big of a draw as you might think, especially more recently. A typical wireless router for example needs no more than 10 W peak these days, often somewhat less (and the amount will vary by actual network usage, because a large chunk of that is actually the transmitters), so it will generally only be in the single-digit kWh in terms of monthly consumption. Still a nontrivial amount, but less than 1/10th of a refrigerator, and less than 1% of a typical household power budget in the US. – Austin Hemmelgarn Jul 17 '22 at 17:34
@Austin but when you have a lot of them, they add up. Remember a modern refrigerator only averages around 38 watts, or less than 1 KWH per day. Plug a Kill-a-Watt into one for a week and see for yourself. – Harper - Reinstate Monica Jul 17 '22 at 17:51
1Lots of good comments here, @AustinHemmelgarn I agree the current draw by electronics is lower that it used to be, but since they are on 24/7 it still adds up. A typical electric oven element draws about 3,000 watts (they vary), but that's about 36 cents per hour at 12 cents/KW. So a 20 minute bake, adding 10 min for warmup would cost a max of 18 cents. Much less in reality since once up to temp, it'll start cycling on and off to maintain temp. I don't know much about toaster ovens, but don't they stay on all time? Next: You need to look at the DIFFERENCE, then your down to pennies. – George Anderson Jul 17 '22 at 20:52
3I'm getting conversational here, sorry, but here goes: 1) typical electric and gas ranges are not very energy efficient because a lot of the generated heat doesn't actually heat the food (talking range top here), esp. gas. If you really want to be energy efficient cooking go **induction**, virtually no wasted heat. 2) In hot climes where a/c is used a lot, cook outside! Good excuse to get a great RecTeq pellet grill/smoker! Throw the pizza on it, grab a couple of cold ones, added benefit is a mild smoky flavor added to the pizza! (I might get snipped for a product recommendation!) – George Anderson Jul 17 '22 at 21:06
3@GeorgeAnderson not all toaster ovens stay on all the time (depending on the setting). The only one I have significant experience with had a mode where both top & bottom elements were on, but set to a temperature and would turn on and off, or you could have *either* top *or* bottom element on continuously – Esther Jul 17 '22 at 21:13
2I will say you can use a microwave to cook a pizza, but it will not be something you want to eat afterwards https://www.iceland.co.uk/p/chicago-town-2-deep-dish-four-cheese-mini-pizzas-2-x-155g/651.html – Tim Jul 17 '22 at 22:28
1Ovens are typically not heating the entire time, either. They heat up to the set temp and then switch on and off, keeping the actual temp around the desired one. The fraction of time they are actually heating depends on the set temperature which, admittedly, is fairly high for Pizza. – Peter - Reinstate Monica Jul 18 '22 at 15:24
@Peter-ReinstateMonica Which is exactly my point about duty cycle. – manassehkatz-Moving 2 Codidact Jul 18 '22 at 15:28
1@GeorgeAnderson having just visited an elderly relative, as modified by the lighting level: perhaps because incandescent lights are such power hogs and heat sources / fire hazards, we have FAR brighter (LED) lighting in our home than my relative. E.g. in our (larger) main room I put in 19 track lighting heads with 65W equivalent (12W) LEDs: 1235W equivalent (228W actual). My relative has three table lamps with 150W bulbs in the living room, and usually leaves most of them off. The hall fixture has four 25W bulbs. I have to use my cell light to read the thermostat... – Technophile Jul 19 '22 at 04:33
2@Technophile ooohhhkkkayy....I have no idea how your comment addresses anything I said. I have LEDs on all the commonly used lighting in my house. no disagreements that incandescent have two problems: 1) they are power hogs, as you said. About 90% of energy use goes to heat, not light , and 2) in hotter climes where A/C is used a lot they just add heat to conditioned space that subsequently needs to be cooled. I'm remodeling a house now and all lighting will be LED and the range will have an induction cook-top. So if you have anything to say to me, please clarify your comment. – George Anderson Jul 19 '22 at 05:52
1@GeorgeAnderson as a bit of a toaster oven aficionado, I've _never_ seen one have the heating elements on all the time when used in _oven_ mode - the elements cycle on and off, just like the big oven. For toasting, yes, they're on the whole time, but the point of toasting is to burn the bread as quickly as possible, so it's a different process. – FreeMan Jul 19 '22 at 16:08
@FreeMan 100% agreed. Which of course gets back to the duty cycle. 1500W, 3000W, etc. is all irrelevant if you don't take the duty cycle into account, which is, to me, the fatal flaw in these "save energy with a smaller device" articles. If size was all that mattered, we'd just use EZ Bake Ovens. And then replace with LEDs... – manassehkatz-Moving 2 Codidact Jul 19 '22 at 16:11
1LOL! Sadly, the days of the EZ Bake oven has gone. 100W incandescent bulbs are as rare as hen's teeth, and worth significantly more than their weight in gold. – FreeMan Jul 19 '22 at 16:13
1@FreeMan Funny comment. A few years ago when they practically banned incandescent bulbs I bought 2 boxes of 48 bulbs each 100 watts bc I was mad at the gov't intrusion. I still have about 50 left. Maybe I'll go on Antiques Road Show and see what they're worth! LOL. BTW for the EZ bake, there are "rough service" (like are placed in trouble lights) still available. The full ban on incandescent bulbs (with some exceptions, like rough service) takes effect 8/1/2023 so they are still available for now. – George Anderson Jul 19 '22 at 21:21
@GeorgeAnderson you wrote "Lighting, with LEDs so efficient now, I don't believe lighting is a major draw." As lighting becomes more efficient, it's feasible to consume more OF it, increasing the draw. – Technophile Jul 20 '22 at 22:40
1@Technophile for LED lighting to draw as much as an oldfashioned incandescent bulb, you'd get TWENTY times the output in lumens. Yes, there is a slight rebound effect, but unless you're planning to wear sunglasses inside and getting a serious tan while attempting to watch TV in all that glare, lighting in the LED era will not draw more energy than before :) – MiG Jul 20 '22 at 22:48
@MiG straw man argument. I didn't say the improved efficiency was completely counteracted, more that there is another factor to consider. – Technophile Jul 21 '22 at 01:30
Perhaps you meant different, but *"increasing the draw"* suggests drawing more than the original (incandescent) situation, which would be the proverbial very different ball game. I would not worry about being slightly less efficient lumen wise considering the massive increase in efficiency, it will have very little effect :) – MiG Jul 21 '22 at 01:40
You might be getting confused by North American split-phase power, which is quite a headful.
The answer is, North American homes get 120V... but twice. The two banks are opposite-phased, so they can stack to 240V.
The toaster oven draws one bank of 120V... you are drawing 14A off one bank. The range draws both banks of 120V @ 12 amps, and you need to pay for 12 amps off both banks - i.e. you are drawing 12 amps twice.
You could call it 24A for billing/comparison purposes... but it's actually 12A at twice the voltage.
If your quibble is how the toaster oven draws slightly more at 14A vs 12A, well... the oven being 12A is random*. The toaster oven being 12A is expected. Most plug-in appliances in North America have maximum "1500 watts", because that is all UL will approve. UL assumes 125V since voltages often exceed 120V - 125V gives 12 amps. 12 amps is exactly the plug-in appliance limit on a 15A circuit, per NEC 210.23(A)(1) (plug-in appliances can't exceed 80%). Of course, with unregulated, non-complying foreign goods sold direct-mail, all bets are off.
* Well, not entirely random. The "80% of circuit ampacity" mentioned later in the paragraph applies to hardwired loads too, so the 12A oven is sized just right to be on a dedicated 15A circuit.
- 295,284
- 26
- 275
- 720
The answer to this depends partly on what you mean by "bake pizza".
Baking a pizza really well from scratch requires stored energy and high temperature, hence people use pizza bricks or pizza ovens. If you do it that way, your toaster oven is probably not capable. If you try to heat bricks in it, you'll lose a lot more energy due to its relatively poor insulation. In fact, the bricks may never fully heat up for the same reason.
On the other hand if what you're doing is reheating a frozen pizza or just melting a slice of cheese on a slice of bread, the toaster oven may be more efficient since the toaster's heating elements are acting directly on the food, not heating up the oven itself as much and more importantly, not preheating the substantial metal casing of the larger oven.
- 34,254
- 2
- 43
- 136
1Modern convection "toaster" ovens do a bit better at this. The insulation is better and between the convection and being a lot closer to the heating elements they have no problem with high temperatures. – user3067860 Jul 18 '22 at 18:11
1There's also the obvious size difference - no toaster oven I've seen could fit even a small personal-sized 8" diameter pizza in it. At best, you could fit half of that at a time and cook each half separately. If you're just heating up a slice, it's fine, but baking a whole pizza - even a small one - is nearly out of the question. – Darrel Hoffman Jul 19 '22 at 13:55
3@DarrelHoffman being able to fit a 12" pizza was one of the requirements for our latest toaster oven. There are scads of them made explicitly to meet this requirement now. I will readily admit, though, that the one I got has _terrible_ insulation. It quickly gets too hot on the outside to touch it. – FreeMan Jul 19 '22 at 16:10
I have a very simple answer for this.
P = V * I If you are looking for power consumption we can calculate it as so:
Oven: P = 240V * 12A = 2880 W
Toaster: P = 120V * 14A = 1680 W
We will assume that these take the same amount of time which implies that the Toaster is a better power consumption rate.
A more advanced answer is that we can assume the pizza will take 15 minutes to make and the toaster takes 1 minute to heat up whereas the oven takes 10 minutes. The units for power is W and that is equal to Joules/second. We will assume that the toaster needs 16 minutes and the oven needs 25 minutes.
oven energy: E = 2880 J/s * 25 min * 60s/min = 4320000 J or 4320 kJ
Toaster energy: E = 1680 J/s * 16 min * 60 s/min = 1612800 J or 1612.8 kJ
The toaster takes 3 times less energy to make a pizza.
If you have different oven specs, feel free to just recalculate these values.
- 1
- 1
1While your calculations are correct, they are already explained in the (currently) most highly up voted answer that was given 2 days ago. Simply repeating another answer isn't very helpful. – FreeMan Jul 19 '22 at 16:12
Yes, but I included more detailed information (energy consumption), which includes estimated warmup time. – Isaiah Ryman Jul 27 '22 at 16:35
