I'm trying to replace 2 sets of three way switches with smart switches.
One end of each set requires neutral, and unfortunately there doesn't seem to be a straight forward way to accomplish that with my wiring.
I've put together a diagram showing the wiring that I'm hoping will be helpful. This is my best understanding of what's going on but there may be mistakes so let me know if anything looks off.
My question is, is there anyway to get the neutral wire I need for both sets of switches? Both lights are on the same circuit if that helps.
Failing that, is there a setup that could allow me to replace one or both of these sets with single pole switches instead?
wiring diagram
kfoley
  • 151
  • As you drew it, Switch 4 has nothing to do with the light that is controlled with switch 2. In fact switch 4 appears to dump power into the neutral to switch 2. Is that really what you intended? Maybe fix your color scheme – Carl Witthoft Aug 15 '22 at 17:24
  • I'm guessing that in your diagram, all four switches are traditional 3-way (SPDT) switches with the common terminal at the bottom right and the two switched terminals at the top left and the top right. Is that correct? – Tanner Swett Aug 15 '22 at 18:14
Switch 1-3 are part of an old fashioned switch loop.
Switch 2-4 is a "lamp in the middle" sort of deal.
How to do it, though.
Things are made more difficult by the system being powered from 2 different power sources. By sheer luck, one of them can feed the whole shebang. Not the switch loop. That gets deleted altogether (capped off).
Now we have
Sorry for the bad photoshop, its line tool suddenly started painting random colors instead of the foreground color I selected.
The top left power feed is GONE. I recolored the top left cable from black-white to red-white. Colored electrical tape is amazing!
In all cases, black=always-hot, white=neutral, and red=switched-hot.
Switch 1 and 4 are smart switch "masters" for their respective lamp. Switches 2 and 3 are smart switch "remotes".
Note that the 1-3 pair have the red wire available for inter-switch signaling if they need it. However switch 2-4 does not, and it MUST be a type such as Insteon that uses wireless or powerline signaling for the remote to talk to the master.
    Your first two diagrams are identical. What did you intend? – Carl Witthoft Aug 15 '22 at 17:20
  • @CarlWitthoft It looks to me like the first two diagrams are _functionally_ identical, but the first one shows that the lamp is physically in between the supply and both switches, whereas the second one shows that the lamp is physically in between one switch and the other switch. (If the goal is to be spatially accurate, then the first diagram should show the always-hot going all the way to the most distant switch, and the switched-hot coming back from the nearer switch.) – Tanner Swett Aug 15 '22 at 18:21
