Over the last several weeks we've noticed a sewer gas smell in our upstairs bathroom at night when we run a whole house exhaust fan in the bathroom window. I found that in the basement where the plumbing chase is exposed, there is a slight draft where the smell is strongest.
The drain stack is the original cast iron, though over the years portions have been replaced with PVC, and most of the lateral lines have been replaced with copper, PVC, or steel.
Here's what I've tried so far:
  • Running drano through all the drains and re-filling p-traps with water
  • Confirming that all drains are properly draining
  • Checking the roof vents for obstructions
  • Replacing the wax ring on the upstairs toilet (downstairs toilet was installed less than two years ago)
What should I check next? Before opening walls and looking for loose plumbing connections, what else should I try?
Below is a diagram of the entire drain and vent system.
Plumbing drain and vent diagram
LShaver
  • 1,296
  • 33
    I had that, and the toilet needed to be reseated. Toilets have the p-trap build in, but. they can leak/fumes at the wax seal. – asinine Aug 28 '22 at 18:19
  • Before you freak out about replacing the pipes, Do you see any leak or dripping, or wet pipes anywhere ? – asinine Aug 29 '22 at 01:01
  • @Ruskes no drips/leaks anywhere that I can see -- but if there's a break somewhere in the vent stack, there wouldn't be any water to detect. – LShaver Aug 29 '22 at 01:07
  • correct about vent stack, The exhaust fan is in the upstairs bathroom, window there is the smell, mostly in the morning, after the fan run all night ? It might be drying up P-trap – asinine Aug 29 '22 at 01:35
  • @Ruskes well it wasn't the wax ring, I replaced it yesterday and the smell was back tonight. It's worst in the morning, but present at night too, so I don't think it's just a dry p-trap. – LShaver Aug 30 '22 at 02:12
  • well we (you) tried. Is the smell only there when you run you huge exhaust fan ? In the morning is when nobody flushed toilets, but as soon you start flushing the smell goes away, would indicate a dry P-trap. – asinine Aug 30 '22 at 02:57
  • @Ruskes Actually I tested this with the drain of a shower we don't use often, and it did seem to help. Any idea why the p-trap would dry out so fast, and what I can do to fix it? We live in a humid climate and I've never experienced this before, so it seems strange. – LShaver Aug 30 '22 at 13:45
  • This is getting interesting. You are creating negative (lower) pressure with your huge exhaust fan. How to prevent p-trap drying out, put a rubber seal in the drain. We will solve this without scarry cast iron answers. – asinine Aug 30 '22 at 17:14
  • @Ruskes getting closer. I've discovered that when I put water in the first floor shower drain, the smell stops. Then, as soon as the toilet in that room is flushed, it comes back. So it seems that the toilet flush is siphoning water out of the shower p-trap. As a first step I've tried removing the AAV and cleaning it out really well (it was coated in some construction dust). Are there different grades of AAV? – LShaver Sep 11 '22 at 18:02
  • You are on the correct path. Maybe the AAV is not doing its job. – asinine Sep 11 '22 at 18:22
You might be seeing the end-of-life of the (I'm guessing) cast iron pipes in the plumbing chase. They last a long time, but past 100 years or so they can get chancy for corroding through.
To me, a plumbing chase typically means plumbing was added to the building after it was built, and that might well have been before 1922, so it begins to be thinkable.
  • That sounds like a fun problem to fix! The house was built in 1919 so it's possible. If this were the issue, what's the first place to check? Top or bottom? – LShaver Aug 28 '22 at 19:44
  • Often the problem is not with the pipes themselves but rather the joints, especially with old cast iron pipes. – Hot Licks Aug 28 '22 at 21:40
    Try narrowing the problem, close all of the rooms off and later check where the strongest smell is. Yes keep the ventilation fans off. – Gil Aug 28 '22 at 23:43
  • @Gil we're headed out of town for a bit, I'll give that a shot. – LShaver Aug 29 '22 at 00:53
  • Good luck I hope it is an easy fix! – Gil Aug 29 '22 at 15:06
If you feel that the pipes are still in decent shape but an oakum / lead joint in the main stack may be leaking air -- possibly due to shaking in the 2008 quake in your area -- then you may be able to find the air leak with a smoke machine.
I've never done this myself, but I've heard of it being done. If you stand below the chase with a flashlight and/or a laser pointer, you may localize escaping smoke to a particular area and eliminate much exploratory hacking of walls.
MTA
  • 10,913
  • Question did sound like a joint leak. This with location and type of pipe should help. Did not know about smoke for leaking joints. – crip659 Aug 28 '22 at 21:18
    I'm not sure I follow... where is the smoke machine in this scenario? And if the failed joints are in the wall, how does this help me find them? – LShaver Aug 29 '22 at 00:54
  • @LShaver "In the basement where the plumbing chase is exposed . . . ." You can stand in the basement under the chase and look up with a flashlight to see the pipe and all the pipe joints straight up to the attic, right? That's how it was in a 1950 house where I lived. If you can't, or you can't see the same from the attic then there's no point in using smoke. The smoke machine can be either on the roof attached to the vent or in the house feeding any sink drain whose P trap has been cleared of standing water, with a loose cap covering the roof vent. – MTA Aug 29 '22 at 01:53
  • Ah OK. Well the chase is a stud bay in a 2x6 wall, and there's water supply pipes and some electric conduit too, so I can't see very far up it. – LShaver Aug 30 '22 at 02:16
  • This sounds like an excellent suggestion, even if a couple of exploratory holes must be opened in the walls to look for smoke. Consider removing switches/outlets and their boxes if you happen to have any in the stud bay/chase - they are ready made holes that are easy to "patch" by putting everything back. – FreeMan Aug 30 '22 at 14:25
