I have installed lights in my house. The lights don't appear to flicker to the naked eye. However, when I view them through the video camera on my iPhone, the lights appear to flicker at a very high rate.
Is this bad for my health? Are the lights defective? How can I fix this?
bubbleking
  • 510
Eyal Cohen
  • 165
    The flickering is picked up due to two rates that it didn't sync up with: 1) refresh rate of the camera capturing device 2) refresh rate of the display. If it happens to not be a matching rate of BOTH of these, then you'll see flickering. – Nelson Sep 29 '22 at 02:52
    [This is more to do with photography than DIY, so just as a comment] You **can** get totally flicker-free LEDs, but they're usually specially for video lighting [& expensive]. Many of the rest [domestic, cheap ones] flicker at some multiple of your national mains frequency. Some video cameras have an anti-flicker setting, but for stills you need to try set your exposure time to also be a multiple of your mains frequency, which can be tough from a phone, easy on a real camera. – Tetsujin Sep 29 '22 at 07:42
    Different people can see flicker differently. If you can't see it naturally, then forget about it. If you can see it, like me, you're in for a life of pain as you try to find flicker-free lights. Hint, peripheral vision is faster than central vision for seeing flicker. VTAC is a cheap brand of LED lights that I've found most examples of are flicker-free. Often expensive brands are flicker-free, but not always. – Neil_UK Sep 29 '22 at 10:36
  • What is the mains frequency where you are? [How to Remove Light Flicker While Recording Video on iPhone](https://www.neuf.tv/en/how-to-remove-light-flicker-when-recording-video-on-iphone-gadgets-to-use) *might* be helpful. – Andrew Morton Sep 29 '22 at 18:37
  • If the flickering is a concern while filming, you will need to upgrade to a camera that can be gen-locked to your lighting system. – Glen Yates Oct 05 '22 at 14:31
LED lights actually flicker very quickly. It only shows up in video, your eyes don't care.
It's fine.
Tiger Guy
  • 1,564
  • No you’rewrong. I have other lights which is flicker free. So i was wondering if i should upgtade my current flickering lights. – Eyal Cohen Sep 28 '22 at 17:24
    It may be, @EyalCohen, that the "don't flicker" lights just so happen to flicker at the same speed as the shutter of your camera. They do flicker. If you have/know someone who has a camera with a manual shutter speed control, set the shutter speed to about 1/1000 second and take some pictures of the lights. You'll get pics with some lights on, some off, even though you and your phone can't see them flicker. I've done this taking pics of scoreboards at gymnastics meets - hard to read the scoreboard with ~20% of the lights on... – FreeMan Sep 28 '22 at 18:33
    @EyalCohen if "flicker-free" onvideo is important to you you'll need different lights or a different camera shutter speed. If you think it's bad then why ask? – Tiger Guy Sep 28 '22 at 23:31
  • @EyalCohen Try recording your 'flicker free' LED lights in super slow motion, and you will see they flicker. Check out this (and other) youtube video of Le Mans racing cars: https://youtu.be/KXUcuD_imyU?t=23 The Audi at 24 seconds appears to have the headlights flash randomly. This is because of the LED frequency being high enough not to show up normally but it does in slow motion. – ThaRobster Sep 29 '22 at 09:26
    @ThaRobster: It's entirely possible to make LED lights that don't flicker. Very often they do, because many of the efficient/cheap ways of driving them do make them flicker - especially if there's any sort of dimming (and, as many have said, it largely doesn't matter if they _do_ flicker). But there's nothing inherent about LEDs that means they _have_ to flicker. – psmears Sep 29 '22 at 09:44
    @ThaRobster - that depends heavily on the exact LED driver used. Some drivers drive the output at a high enough frequency that they don't show up normally, but some drivers do actually drive a (reasonably) constant current in the output. – TLW Sep 30 '22 at 01:25
    Adjusting the true intensity of an LED is difficult; they can be very sensitive to even minor changes in voltage. Adjusting the apparent intensity through flickering is much easier. – Arthur Sep 30 '22 at 11:36
    @Arthur controlling the current instead of the voltage is not difficult. – user253751 Sep 30 '22 at 18:15
  • The point here is that unless you're making a movie is doesn't matter. – Tiger Guy Sep 30 '22 at 19:22
  • @user253751 The only way I know of to do that (with my admittedly small knowledge in the field) is hooking it up in series with a resistor and lose all that energy to heat, which defeats some of the purpose of leaving incandescents and also risks damaging the driver. Do you know a better way? – Arthur Sep 30 '22 at 19:32
    @Arthur a constant-current switching regulator is not much different to a constant-voltage switching regulator – user253751 Sep 30 '22 at 19:36
  • @user253751 Current controlled switches are a bit more expensive then voltage regulators... It is cheaper to detect the voltage between point A/B then the current flowing between A/B. – Questor Sep 30 '22 at 19:39
  • @FreeMan. I thought that they flickered faster then your camera's shutterspeed. if they flicker at the same FPS as your video recorder it would be possible for you to get a recording where the room is dark and the lights are always off. Even though the room is visible (You practically have to do it on purpose. But its cool... Same reason that a spinning fan can look motionless under a strobe light if the fan syncs up with the light). – Questor Sep 30 '22 at 20:38
  • @Questor They just add a small resistor and use the resistor voltage as feedback. – user253751 Sep 30 '22 at 23:13
    I think there is some variation in flicker speed, @Questor. I can see taillights on a Cadillac (but, fortunately, not other brands) flicker at night just looking at them. I see LEDs flicker on race cars in video at 30 or 60 FPS. As noted above, I've captured LED displays (at a high shutter speed) with 1/2 or more of the lights "off" when they were all on to the naked eye (and I didn't see any flickering without the camera). I believe it depends on the electronics in the drivers of the particular lighting unit. – FreeMan Oct 03 '22 at 12:40
13
The majority of artificial light sources flicker, but they do so with different amplitudes and frequencies.
If you have lights powered by direct current (DC) from a battery:
  • An incandescent bulb will not flicker.
  • An LED driven directly or with a resistor will not flicker. But an LED driven with a buck/boost DC-to-DC converter might flicker, possibly at a high frequency.
  • Fluorescent lamps are usually not powered by DC.
If you have lights powered by DC that was converted from AC, they might flicker a little bit due to ripples in the power conversion. Simple converters based on a transformer and filter might flicker at 100 or 120 Hz (twice the power frequency). Better converters based on SMPS might have essentially invisible flicker in the tens of kilohertz.
If you have lights powered by alternating current:
  • An incandescent bulb will flicker a tiny bit at 100 or 120 Hz. The thermal mass of the tungsten will keep the light output pretty steady, but there are still subtle fluctuations of heating and cooling.
  • An LED hooked up directly to power will flicker strongly at 100 or 120 Hz. Cheap Christmas lights, which are strings of LEDs, tend to be like this.
  • Other LED bulbs have AC-to-DC conversion circuitry, possibly with inductors and capacitors to smooth out the power, and possibly use SMPS high-frequency conversion.
  • Old, big fluorescent lamps will flicker moderately at 100 or 120 Hz. The color may shift between orange-ish and blue-ish during each cycle.
  • New compact fluorescent lamps (CFLs) have onboard power converters that will produce invisible flicker in the tens of kilohertz.
CRT televisions/monitors are a great example of strong flicker. You can use them to test how your eyes react, and easily adjust the frequency through video output settings. For example, in my peripheral vision I can see flicker at 50 Hz but not at 60 Hz.
If the flicker frequency is too low (let's say below 50 Hz), it could potentially cause eye strain, fatigue, and disorientation.
Moderate flicker frequencies (say 100 Hz) are generally fine, but can produce slightly annoying artifacts when the light source moves or when objects move. For example, moving your hand under a flickering light source can produce ghost copies of the hand. For example, a flickering car tail light can produce many copies of the light against a dark background.
Another consideration is that in machine shops with spinning equipment, a flickering light source can produce the aliasing illusion that a fast-spinning machine is stopped or going slowly; this can be a safety hazard.
And finally, if the flicker causes visible problems in the photos or videos that you take, then by definition the flicker is bad for that particular use case.
Overall, non-flickering light sources are the most natural to our eyes and cameras, but moderate flicker frequencies (around 100 Hz) can be tolerated by our eyes very well.
Nayuki
  • 235
  • This account isn't linked to your profile. – Mazura Sep 29 '22 at 00:55
  • @Mazura Maybe you're referring to how I hid communities where I haven't earned a significant number of reputation points above the 101 baseline – Nayuki Sep 29 '22 at 05:54
    Actually, a lot of LED's are driven by a pulsed source, with the overall brightness then controlled by the duty cycle of the signal, so its's not just those driven by the mains. – MikeB Sep 29 '22 at 10:34
If you can't see it, then it does not matter. But some people are more sensitive to flicker than others.
With LEDs, the amount of flicker depends on the quality of the LED driver circuit. If you care enough to change the lamps, try better quality ones from a reputable manufacturer.
Simon B
  • 3,758
    It's not just LEDs that exhibit flicker. Old CRT computer monitors used to refresh slow enough that I could see them flicker, but nobody else could. I'd bump the refresh rate up on mine as high as the video card would support, but everyone else thought I was crazy. – FreeMan Sep 28 '22 at 18:30
    @FreeMan I can also see it. 60Hz was the minimum I needed, but some people wouldn't see it even at 50Hz. Also, your peripheral vision is more sensitive to flickering than directly looking at it. – Nelson Sep 29 '22 at 02:54
  • The higher the quality the less flicker right? – Eyal Cohen Sep 29 '22 at 06:05
    @EyalCohen yes ... if by "better quality" you mean flickers less! A flickering lamp usually means they under-sized the capacitors to save money. – Simon B Sep 29 '22 at 08:21
First, look at the light from the corner of the eye. It will be easier to catch some flicker, peripheral vision is more responsive than foveal.
If you don't see any flicker, lights are good enough for you. You might still want to replace those bulbs to take better videos inside, but it isn't a must-have. Guests that are more sensitive to flicker could notice it though.
If you see some flicker, even if just slightly, I suggest replacing the light bulbs. Flicker won't do any noteworthy damage by itself. But it will tire you and watching that can be stressful, so it may do some damage indirectly. Fairly fast and cheap bulb replacement is a very cost and time efficient improvement.
The only reasonable thing you can do here is replacing the bulb if needed. You shouldn't try to fix bulb. The main problem is that cheapo bulb skimped on capacitors and so there is not enough smoothing of the AC sine wave towards something resembling constant DC. You get voltage and current variation, meaning brightness changes. It IS possible to open up the LED and replace electronics. But this operation will only fix amount of flicker and bulb efficiency at the cost of brightness - colors will remain the typical poor 80-ish CRI of cheap bulbs. I consider this a waste of effort over simply buying a better bulb; if you really want to do a lot of DIY here you can buy OEM LED chips and assemble the whole thingy yourself.
All AC LED bulbs I saw flicker. Most of them flicker at 20 kHz, give or take few 10s kHz. You won't see that with eye or on a typical home camera, but you can see it on a high-speed camera. Cheap bulbs flicker at lower frequencies, those are noticeable by eye or normal cameras. DC LEDs either flicker or not.
Zizy Archer
  • 151
    The other thing that will help detect flicker besides using your peripheral vision is to turn off all other artificial light sources (and maybe do this at night or in a darkened room), and then wave an object (e.g. your finger) back and forth in front of the light. You should be able to see a strobe effect of the object's movement. – Darrel Hoffman Sep 29 '22 at 21:15
The is-this-bad-for-health part of the question has not been answered yet. You would have to turn to scientific literature. Following are two links to papers and while I didn't read them fully, the abstracts imply that there can be negative effects on health like eye strain and headaches.
Potential Biological and Ecological Effects of Flickering Artificial Light
Light Emitting Diode Lighting Flicker, its Impact on Health and the Need to Minimise it
this
  • 35
