We live in a very large, old house (in the UK) with 8 bedrooms, heated by an Ideal Instinct Heat 60 boiler (about six years old) supplying 32 radiators and a 295-litre (65 gallon) water cylinder. With the latest price rises, we are currently estimating an annual cost of up to £12,000 for gas alone, which we just cannot afford.
We are implementing all the cost-saving measures we can think of as regards the heating (the main one being leave it off until our fingers turn blue!) but the thing that bothers me is the water. There are only 3 of us in the house, so heating 295-litres of water at a time is hugely wasteful. We don't have a smart meter, but by my rough calculations I reckon it's currently costing £6-8 per day for water alone.
We installed the system when gas prices were much cheaper, thinking that even though there weren't many of us in the house, a future owner would probably have a much bigger family, so a cylinder would be more appropriate than a combi. But gas prices have now risen so much that we are having to reconsider.
I have a few questions; if someone has the time to consider them, I would be most grateful:
Question 1 - I am assuming that this is a clear 'no', but can you get boilers that work in either 'combi' or 'conventional' mode, so you can switch between modes?
Question 2 - Are there combi boilers that can cope with the demands of 32 radiators and 6 bathrooms, and how much are we likely to have to pay for one (supplied and fitted)
Question 3 - Is there any other way to reduce the capacity of our cylinder, so we are heating less water every day (e.g. would it be worthwhile replacing the big cylinder with a much smaller one, with the option for a future owner to switch back?)
Many thanks for your time.
    90% of the time an old house means very poor or no insulation in the walls/ceilings plus drafts. Fixing this will help quite a bit. Can probably add pipe insulation and blankets to the tanks. – crip659 Oct 12 '22 at 12:37
    Unless you're _using_ 295 liters of water all at once, you're never _heating_ 295 liters of water all at once. You've heated it once, and it stays (mostly) hot, with just a touch up now and then as needed. Of course, if you take a shower, wash your hands or dishes, or otherwise _use_ hot water, it'll kick in to heat some new water to replace what was used, so maybe focus on short showers and _quick_ washes... – FreeMan Oct 12 '22 at 12:48
    "Standby losses" for an electric tank of moderately decent insulation documented here: https://diy.stackexchange.com/a/244644/18078 – Ecnerwal Oct 12 '22 at 13:31
  • Hot water use is 40-60 litres per person per day at 60 deg C. Also the tank stratifies and the hot water is only down to the level of the thermostat - not normally the bottom of the tank. So read the two answers again taking into account the points I made. – Solar Mike Oct 12 '22 at 16:15
  • As for cheaper solutions you can consider solar water heating. – Solar Mike Oct 12 '22 at 16:16
  • A combi runs as a conventional if you're not running the hot taps. I don't know why you opted for a tanked system rather than instant… I can only guess it's the distance to the farthest taps & pressure for the shower. You might investigate much, much shorter run instant electric to the longest runs, especially kitchen where there will be frequent but low use. You can waste a couple of gallons just running the tap til it's hot. Also, instant electric showers. Fairly large initial investment, but then you're only paying for what you use, & not leaving gallons to go cold between uses. – Tetsujin Oct 12 '22 at 16:37
  • £12,000 will pay for a whole lot of alternatives. The boiler system is grossly wasteful no matter how new it is. I would shut it down except for the coldest days of the year. For water heat, electric showers (£200 units) or smaller ~100ltr/30 gal electric tank near bathrooms, works great for Americans and we love high flow LOL. For heat, extended range "mini split" heat pumps. *Bad news: these also provide A/C*. I would treat the boiler as "emergency heat" and only fire it when the weather report predicts cold beyond the ability of heat pumps to handle. – Harper - Reinstate Monica Oct 13 '22 at 00:13
A six year old boiler should be quite efficient, so replacing it seems unlikely to be a good choice. A really well-insulated water cylinder takes days to cool off with no use, so it's quite true that the heat used there (if not being wasted by poor insulation or uninsulated/poorly insulated pipes) is almost entirely just the hot water you actually use. So be sure you have no hot water leaks, and put the insulation to it, rather than replacing it.
Concerned about your hot water cylinder wasting energy? Add more insulation to it. Add more insulation to its pipes. How big it is is almost immaterial to how much energy it uses, if it's properly insulated.
Concerned about the sky high cost of heating a very large, old house? Air sealing and insulation are the commonplace, everyday, boring things that make a HUGE difference in fuel consumption, but nobody thinks to start with them, usually, because they are commonplace, everyday, and boring. Caulk or foam air leaks in the house and insulate the house to limit waste of heat for heating. Use heat shrink plastic films over drafty windows to allow light in but block drafts and add a bit of insulation. Use rigid foam insulation and/or blankets/heavy drapes (held right to the window, not spaced out as drapes usually are) to block windows in unused areas, if you are heating those areas at all.
The other standard practice for large old houses in winter with only 3 people occupying them is to close off large parts of the house and only heat what you actually need to live. Either run the rest of the house at 7°C (not lower or you risk some parts freezing) or turn it off entirely, depending on the potential for freezing and whether you can manage to drain all the plumbing (or fill with non-toxic antifreeze) in the closed off sections, or not. If your heating loop is closed, filling that with non-toxic antifreeze mixture rather than straight water will keep the unused radiators from freezing up.
  • Efficient relative to what? If it's using methane then it's not efficient at all. Another way of saying that is, "Just because methane was chosen 6 years ago does not make it a good choice today, and this being the case, may cause the heater to become **obsolete** before its end of mechanical life". – Harper - Reinstate Monica Oct 13 '22 at 00:02
  • Questioner was proposing replace gas with gas. There's not much change in gas appliance efficiency from the last 6 years. If a 12,000 UKP heating bill is prohibitive, ~10X that to rip out and replace with heat pumps in a large drafty building is likely also untenable. Electric rates may also be rising there, don't know how the gas *.vs.* electric BTUs/UKP relate at present. In my general area, Gas is still cheaper if you can get it (but it doesn't come *From Russia, with Hate*) but there will never be a gas line on my road, most likely, and bottle gas is far more expensive than electricity. – Ecnerwal Oct 13 '22 at 15:50
  • The issue isn't the raw efficiency of turning gas into heat. I'm talking about the efficiency of how their system is laid out - being a massive hydronic HVAC + water heat system which heats a house MUCH larger than their needs. Mini-splits (I was unaware they cost 120,000 quid in the UK) would allow them to select their zones, and as for efficiency, see here. https://www.youtube.com/watch?v=MFEHFsO-XSI Gas we *don't* use domestically can be shipped to our European allies to reduce their need for Russian gas. So it's all a shared pool, really. – Harper - Reinstate Monica Oct 13 '22 at 22:12
First of all, I'm not sure what you mean by "conventional and combi" modes...would that mean domestic hot water and hot water for heating? If you could provide a layout of your current system that would be helpful. When you do so, please EDIT your answer clarifying your questions and adding the diagram.
That said, from what we know now:
I wouldn't consider reducing the size of the hot water tank. You have a large system that needs lots of hot water. Once the water is hot, it stays hot unless the tank is poorly insulated, which can be fixed by adding an insulation blanket around the tank. With no usage it would only require very occasional firing to maintain temp. You aren't heating 295 L of water at a time, you are maintaining temp of 295 L of water and the gas required to do that is totally dependent upon usage (by your heating system) . Also, since your boiler is only 6 yo it's probably pretty efficient to start with.
So it doesn't matter if you're heating 50 gallons or 500, what drives your gas consumption is USAGE . Since you said it was a large home with only 3 ppl living there, are there zones you can turn down the heat in? Most radiators have valves as well to control the amount of heat delivered to that room that could be throttled back. Dependent upon your personal usage of the house AND how the piping is laid out, your best investment might be to create zones (if they don't already exist) that can be set to not heat unused parts of the home or partially heat those bits to avoid any freezing pipes.
Also if possible adding insulation to the home may reduce the heating expense. Even clear plastic over single pane windows can help.
Lastly, and this is off topic and might get deleted by a moderator, but let me say in compassion, I really feel for my EU brethren and what you are going thru with energy prices due to this stupid war.
George Anderson
  • 23,066
  • 35
  • 79
    Stock British boiler terminology, but even visiting friends there I'm not always clear on their exact meaning. – Ecnerwal Oct 12 '22 at 13:17
  • Wow, we certainly agree on the remedies, we both said practically the same thing!: Add insulation to the "cylinder" (using their term), add insulation to the home, add clear coverings over windows, esp. single pane ones, not heating parts of the home not in use, or at least reduce it to those parts. In short: Minimize use and seal/insulate to the extent reasonable. ....continued below. .... – George Anderson Oct 12 '22 at 17:42
  • ...continued from above, the only issue is we don't know enough about the piping layout yet, there may not be any zones at all, other that one huge one for the entire home. Our church has an old parsonage home, 3 floors, heated with hydronic radiators and base boards, all on one zone, no control valves, one T-stat. There are baffles on the baseboards to someone control heat delivery to that room. Closing them down results in warmer return water, minimizing usage. Also the radiators have valves to control the usage. Again, we agree: minimize usage and add insulation. – George Anderson Oct 12 '22 at 17:47
