I have used putty on the wall to fix the holes, and fill some gaps. the putty color is white while the rest of the wall is an older light green, I am painting a very dark yellow, However when painting the putty will give a darker color than the rest of the wall. how can I fix this?
Asked
Active
Viewed 2,245 times
You should use a primer/sealer on the entire wall, before painting.
Or select a paint and primer combination.
Or simply apply multiple coats of paint over the entire wall.
- 78
- 316
- 608
2I've used the pictured paint and don't rate it as highly as separate primer/paint for stain/sheen blocking. I've used several other combo paint/primers and would give the class a 20-30% improvement over straight paint. – HerrBag Mar 11 '13 at 13:23
@Tester101 - When you say apply multiple coats of paint, do you mean over the whole wall including the putty covered areas. or only the non putty covered areas?. thank – Wahtever Mar 11 '13 at 13:44
@Wahtever Spot "priming" with wall color paint, perhaps several spot "primes" until sheens are similar, then cover entire wall. – HerrBag Mar 11 '13 at 15:50
