We just had a crawlspace inspection (unrelated to this topic) and the inspector found one of our support posts was loose enough to be wiggled back and forth. It wasn’t quite touching the concrete pier. Since the house is built (2016, west coast) with all wood support posts on concrete piers, what’s the best approach to stabilizing this one loose post? There’s maybe 1/4” space at most between the post and the pier, so not much room to work with.
We’d like to DIY if that’s advisable, but don’t want to take chances doing it wrong. We’re also tapped out financially due to numerous household repair and maintenance projects lately.
Is it advisable to try and shim it up with a cut to fit pressure treated wood, or do we need to replace the whole post? The post itself is in good condition,it’s just loose.
Any advice?
