There's a cleanout plug on this pipe that I simply can't get loose. I've tried liquid wrench, PB blaster, heating up the area with a torch, everything I can think of. All that's really left is to go after the plug with a drill and a saw and just pull it apart. However, none of my local hardware stores HAVE any 4 inch cast iron, all they have is PVC. Can I put a PVC cleanout plug in a Cast Iron cleanout?
Another option would be to cut the pipe above and below the cleanout, and install a PVC Y-fitting with a cleanout cap using no-hub couplings like these:
I would think that drilling and/or sawing out the old cast iron cap is going to be a giant pain in the rear, and will be likely to damage the cleanout fitting to the point where it needs to be replaced anyway.
Make sure your cast iron stack is supported above before you cut it.
- 9,324
- 1
- 23
- 43
What tools would I need to cut out the old pipe? – philosodad Nov 05 '10 at 14:55
4I'd recommend renting a snap cutter like this: http://www.plumbingsupply.com/snapcutters.html. If you have a reciprocating saw, you can buy special grit blades for cutting cast iron as well, but the snap cutter will be a lot quicker. – Mike Powell Nov 05 '10 at 15:10
@Mike: $460-700 is pretty steep for a DIY tool that you'll only use a few times. – Doresoom Nov 05 '10 at 18:41
I can rent one for $23/day, $50/week. So that's a little easier on the wallet. – philosodad Nov 05 '10 at 19:43
@Doresoom: that's why I suggested he rent one. – Mike Powell Nov 05 '10 at 20:24
1@Aww, crap. that's what I get for not reading thoroughly. Sorry about that. – Doresoom Nov 05 '10 at 20:30
1No problem! I've certainly had my share of those on here too... – Mike Powell Nov 06 '10 at 01:57
1I ended up having to cut the pipe, something further downstream got damaged--the original install was a major kludge job--so I had to replace more iron anyway. The grit blade/reciprocating saw took 5-10 minutes a cut, but it was a long 10 minutes. – philosodad Nov 09 '10 at 01:11
Yes, it should be no problem. Just use teflon tape on the threads to seal it.
I would worry though if you can't get the plug out, that the threads in the pipe won't be any good (or you'll destroy them in the process of attempting to get the plug out). If that happens, you'll need to re-thread the pipe. You should be able to rent a tool for this at your local tool rental place.
You don't mention what the pipe is, so just be prepared that you may not be able to use it until it's repaired, if you do have a problem with the threads.
- 28,910
- 15
- 84
- 160
Its the stack for the upstairs bathroom, but it's upstream and above the stack for the downstairs bathroom. I'm thinking that the best way to pull the old plug is going to be to drill/cut near the edge and pull out the center, then try to heat/break the remaining ring. – philosodad Nov 05 '10 at 14:58
Hole saw out the center and cut a pie shaped piece out with a saws all all the way to the threads but not into the threads, then with a hammer and punch knock out the pie shaped piece and remove the rest with channel lock pliers. Do it every day as a professional plumber. And if the threads are different stop at a local plumbing outfit and get a lead plug.
- 29
- 1
Another options to the PVC one, in case the threads are damanged or the thread count doesn't match up, would be to use an expansion plug:
(I couldn't get the right size for mine at the local store, so I had to also cut down a rubber coupler to make it a closer match to the inner diameter)
- 7,256
- 1
- 29
- 47
I doubt using a test plug will meet code but if you use one of the sturdy metal plugs it will probably work fine. – auujay Oct 19 '12 at 14:47
@auujay maybe not, but surprisingly when I had a home inspection, they misses that the cleanout was covered in duct tape ... when I removed it later, I found someone had shoved a plastic cup in there, then put a plastic bag over the whole thing + layer of duct tape. – Joe Oct 19 '12 at 15:18
