I'm painting my kitchen.
Some areas of the walls had to be repaired with spackle.
Do I need to do a prime coat before I paint? I'm painting the same color. Although I'm changing the finish from eggshell to semi-gloss. Paint is Benjamin Moore Atrium White-- if that means anything.
I'm thinking maybe because it's a kitchen and the repaired area is near sink-- that it might make sense to prime.
ek_ny
  • 415
My dad and his dad were both professional union painters. They taught me that for small spots of spackle on the wall, all you have to do is put a quick layer of regular paint over them with a brush while you're doing your cutting-in brushwork. The spot over the spackle will be mostly dry when you go back over it with the roller later. I know from personal experience that this works. Also, there's no reason to prime if you're repainting a similar color.
I also know from personal experience that if you don't pre-paint your spackle as I described, you will be able to see it after the paint job is done. The color may hide it just fine, but where the rest of your wall is covered with a slight texture from the roller, the spot that was spackled will be smooth. It stands out like a sore thumb. Hitting the spackled spot with your brush while cutting in and then rolling back over it later is all that is needed to fix that problem.
Paul
  • 911
Rule of thumb answer: always use primer.
These days, however, you can buy paints that claim to be 'primer and paint all in one'. I tried some on the flat paint on our kids' walls and it seems to work good enough.
DA01
  • 24,235
  • 27
  • 76
  • 146
Just came across this product, it neatly answers your question. Browsing through a few reviews sites, it seems to be well accepted. Its on my "To Try" list.
enter image description here 3M patch plus primer
Disclamer: I have no financial interest in 3M, its subsidiaries, assignees, unless they have a refer-and-get-rich program.
HerrBag
  • 12,104
  • 37
  • Have you tried this in the meantime? The only hit on this site for 3M Patch Plus Primer is in your answer. – Fizz Jun 18 '17 at 16:22
  • its @ Lowe's https://www.lowes.com/pd/3M-32-oz-White-Patching-Compound/50199663?cm_mmc=search_google-_-FY15%20Paint-_-Dsa%20Paint-_-&k_clickID=fd37d667-3e14-4389-8a14-41d2545b35d3&gclid=Cj0KCQjwkN3KBRCuARIsADT_flr0kwKhb_McI1RkO3jOqMSLzLwmxjzGyAuN8Vthg1fveBWekAvYEO0aAl27EALw_wcB – HerrBag Jul 01 '17 at 16:07
    I have since used it.. Only good for light fills.. Suggest you dampen repair area and possibly the spackle itself (tends to be a bit crumbly, compared to GP joint compound) – HerrBag Jul 01 '17 at 16:11
    Dries quickly and painted well as advertised. Little shrinkage and sanded VERY easily (MUST be painted for proper hardness) – HerrBag Jul 01 '17 at 16:12
