-1
I'm in the planning stages of a home theater setup. What do I need to run to the tv so I can hook up various components? I planned on running power, HDMI cables, RCA cables, coax, and an ethernet cable. Is there anything else I need? Can I run the power in one conduit and run the rest in another conduit or do they need to be run in separate conduits?
John Byrne
    This seems like it's got more to do with your setup than anything else. You need to run all the cables that you need to connect to the TV for whatever devices you plan to hook up to it, right? – JNK Mar 29 '13 at 20:04
  • **DO NOT RUN POWER CORDS THROUGH THE WALL!!!** Have an Electrician install a receptacle behind the television, they even make receptacles that offer [surge protection](http://diy.stackexchange.com/q/2486/33) now. – Tester101 Apr 01 '13 at 10:58
  • This is a subjective question, as the required cables will vary greatly depending on the components that have to connect to the television. – Tester101 Apr 01 '13 at 10:59
As for what wires to run to the TV, it entirely depends on what you plan to hook up. If you're going to have a receiver set up (e.g. to power surround sound speakers) you can run all your devices to that, and only have a single HDMI from the receiver to the TV (plus power). If you're going to run all your individual devices to the TV, you'll need to take a look at what you have.
Running conduit is a good idea so that you can pull more cables later on. I wouldn't install a bunch of extra stuff just on the off-chance you might need it. Make a reasonable plan now and decide what you want. In 5 years there may be entirely new standards so it would be a waste of time and money to try to speculate. Conduit with a little extra room is the best future-proofing.
Hank
  • 14,003
  • 47
    Conduit is your best bet. Baring that, you can carry most signals over 1 or 2 Cat5e, and they're cheap, so you can put 2-4 of those in. – Jay Bazuzi Mar 30 '13 at 02:18
