I just purchased a new cooktop that it is narrower than the cut out of my granite. Would it be OK to have most of the weight just on the ends and not on the front and back? I have a solution I think for the 1/8 inch gap.
Murphy
    that depends on what you will be cooking (the wight) – asinine Jan 12 '23 at 01:31
    You want to trust just the two ends to hold the cooktop plus a big pot of boiling water to hold without tipping over on your kid? – crip659 Jan 12 '23 at 01:36
    You would be smart to support this from below. – Aloysius Defenestrate Jan 12 '23 at 01:44
    I would fashion some timber to hold it from below. You can easily hide it by shifting the cooktop to the front so its supported and put the timber in the back. – Rohit Gupta Jan 12 '23 at 01:47
  • Could even get a piece of matching countertop to put in that space at the back, and support that from underneath... – keshlam Jan 12 '23 at 02:33
    I had to replace my cooktop and my first constraint was to choose only those cooktops that matched the hole in the worktop. But if price was your first constraint then consider the cost and effort for the remedial work. If the gap fill does not provide sufficient strength then it might fail, all those pans full of hot jam... – Solar Mike Jan 12 '23 at 08:11
    @Murphy can you share the dimensions of both the cooktop and cutout? – Huesmann Jan 12 '23 at 14:37
There are two issues. Granite is not that strong as we discovered by sitting on the kitchen benchtop. So you are relying on the strength of the lips on cooktop and the strength of edge of the granite to hold the weight.
I would suggest that you fashion some timber to hold it from below. You can easily hide it by shifting the cooktop to the front so it's supported by the granite and putting the timber in the back. Depending on large the gap is, you could possibly tile the top of the timber to hide it even further and make it more water-proof.
Rohit Gupta
  • 5,090
  • Timber could work, or even rigging up a bunch of the clamps that are used for undermounting sinks to granite counters. Use a filler piece if necessary. OP doesn't say how big the cooktop is, and how big the cutout is. – Huesmann Jan 12 '23 at 14:36
