I recently purchased a solid surface pre-formed shower base. The shower base will be placed on 3/4" plywood. The manufacturer's instructions indicate that I should set the base in thinset. I e-mailed the manufacture and they indicated any thinset will work but unmodified is preferred. I've read that I shouldn't adhere the shower base to the plywood because the substrate will move and swell and contract. The shower base is very solid and doesn't seem to have any flex and the plywood is flat. The shower base will not be attached to the studs so that the thinset would be the only thing keeping it in place (other than gravity, it's heavy). I bought Mapei uncoupling unmodified thinset but wanted some feedback. My questions are as follows:
- What should I use to set the shower base? Thinset, bedding mix, something else?
- Should I put tar paper down on the plywood before putting the mortar down so that the plywood doesn't rob the mortar of its water and/or to provide a sort of cleavage membrane?
- How thick should the mortar/thinset be on the floor?
- Any other advice?
Thanks.
