My garbage disposal currently has a thin piece (head of a butter knife) of metal lodged between the teeth and the wall. I’ve tried using a flat head screw driver, butter knives , etc., but have had no luck on being able to get this un-wedged. The piece of metal is tight on the bottom and the back side of the knife is jammed into the slits that release the water. Any suggestions on how I would be able to get this out?
1If the problem is getting a tool in there, have you tried an angled pick? https://m.media-amazon.com/images/I/71JK1ZbkoEL.jpg – Huesmann Jan 30 '23 at 12:16
2Try using the Allen head screw on the bottom to rotate the mechanism in reverse. With a little luck this will loosen things up for you. – Bob Jarvis - Слава Україні Jan 30 '23 at 21:37
There should be a hole in the center of the bottom of the disposal. A 1/4" allen wrench fits in there so you can spin the insides and loosen stuff stuck in there. You might also be able to jar it loose by rotating a broomstick inside the disposal and wedging it between some of the blades in there. Make sure you unplug it before doing any work. There's also a reset button on the bottom that might have to be reset.
- 78,739
- 18
- 72
- 188
I think your challenge will be to get something underneath to help pry it up, since you can't really come at it from the side due to it being jammed down in the disposal by the disposal tooth. Maybe use a metal paint can opener to use it's opening hook to get underneath the jammed spoon a bit and lift it up?
- 3,773
- 10
- 16
Mike, you can go underneath the sink and disconnect the entire unit. Once off it'd be easier to pry that piece out.
- 17
- 2
2Your answer could be improved with additional supporting information. Please [edit] to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers [in the help center](/help/how-to-answer). – Community Jan 30 '23 at 12:32
2I can't see how it'd be easier. While mounted, the disposal is fixed in place so I can lever against the obstruction or try to force the shaft using the hex wrench. While dismounted, someone has to hold the disposal down to try any of that. Beyond that, disposals are heavy and in cramped quarters. For me at least, removing and installing one involves considerable swearing. – Wayne Conrad Jan 30 '23 at 18:29
@WayneConrad I'm no expert in garbage disposals, but I wonder if Justin thought that working upside down would help, with gravity to get it out once it was free – Chris H Jan 31 '23 at 09:48
Please see [ask] and take the [tour]. While it may be good advice, this doesn't answer the question. – isherwood Jan 31 '23 at 19:49
