In the middle of a room addition; block foundation crawl space just built. I was planning on installing rigid foam board to the interior walls before the framing begins by using a powder activated gun with nails and washers. Can I do this while the walls are wet and leave it exposed to rain?
Evil Elf
  • 3,704
  • 46
  • 56
If you do not have the roof on the addition, DO NOT install the solid insulation. A little moisture and humidity is ok, but if it rains on the insulation panels it can take forever for the water to seep out.
Be patient and have the new space dried in before attaching insulation panels.
RMDman
  • 25,114
  • 58
  • I could install the panels, then seal the top with expanding foam. I could then scrape it level for the joists to be installed on the block. Also tape the joint between panels. Can foam would prevent water from being behind the foam board right? – Evil Elf Mar 26 '23 at 01:49
  • "Can foam would prevent water from being behind the foam board right? –" Maybe...maybe not depending on how hard and driven the rain. All I can tell you is common practice where I am (Fla) is to put up the panels after dry in. – RMDman Mar 26 '23 at 13:39
