The sound is similar to a "buzz" of a high voltage line or a transformer hum. The volume varies with the fan speed rheostat setting and not the actual motor rpm. (Well, more like the difference between the setting and the actual rpm)
Other than being annoyingly loud, is there any electrical danger here? Is it due to improper instalment or lack of adequate insulation?
I'm renting the apartment, so if it is a hazard, then it is the landlord's responsibility to repair it. Otherwise, how would I go about repairing it?
A partially stalled fan motor can make buzzing sounds. Stalling could be caused by friction due to lack of lubrication or buildup of greasy deposits, or mechanical rubbing on nearby parts. Stalled fan motors can get very, very hot. Some house fires have been caused by such overheated ventilation fans. I've personally encountered several little bathroom fans that had been cooked blue, and the surroundings badly scorched. Many range hood fans can be easily accessed after removing the mesh filter element.
kreemoweet
  • 2,538
