I need to buy a new tub spout, but this is what the connector behind it is. Everything I see is either slip on or female thread on the spout itself. I am trying to find something that will work without tearing my wall apart. The piece on there seems to be glued on.
Thank you
Asked
Active
Viewed 64 times
Cody Erb
- 69
- 4
What type was there before? – JACK Apr 16 '23 at 22:05
Look in the tub spout you removed for the "missing" pipe nipple... – Ecnerwal Apr 17 '23 at 02:35
That should be CPVC with female 1/2 inch NPT.
Get a brass nipple in the same thread and length that will allow you to thread on a spout with female 1/2 NPT. Use a thread sealing paste not Teflon tape.
Polly or PVC is not rated for the hot water temps that can flow through the spout.
RMDman
- 25,114
- 2
- 22
- 58
