I'm retrofitting sliding doors on a wardrobe. I decided to use the fixtures from Ikea Hasvik and custom made MDF doors.
The issue: the doors are bending towards the inside of the closet. They are not flat.
The doors are 2400 x 600 x 18 mm Also the ikea system doesn't hold the doors from the top, but from the side. I'm adding a picture that shows the hanging and you can probably see the start of the bending.
Any suggestions on how to prevent this bending?
Many thanks! Paulo
UPDATE: Thanks for your comments.
This was a pack of 3x custom made doors. I see 2 are slightly warped and the third one is OK. I'm not sure what caused it, but as mentioned in the comments could be 1) acclamation and/or 2) the fact I stored them straight up against a wall the first few days... or a mix of both.
I guess my question would be: Is there a way to counter the banana shape?
paulo-m
  • how long did you have it ? it could be the temperature change (acclamation) – asinine Apr 22 '23 at 21:02
  • Are the MDF panels flat when not hanging from the hangers? – gnicko Apr 23 '23 at 12:32
  • Are you using the Hasvik hardware on the bottom of the door too? – Huesmann Apr 23 '23 at 13:20
  • Do you mean **tilting** and not bending? – Steve Wellens Apr 23 '23 at 13:36
  • Thanks for your comments. When I received the panels they were standing up against the wall and stayed like that for 2 or 3 days. I'm thinking that might have warped the panel. I've since installed the bottom fixture and seems to disguise it a bit. Is there any way I can give back its flat shape? – paulo-m Apr 23 '23 at 16:47
  • Short of installing battens, your best bet may just be to let it hang for a while and see if gravity pulls it flatter.. – keshlam Apr 25 '23 at 16:16
  • @keshlam Yeah, I guess I'll do that plus I'll add something to the inside of the wardrobe to push the bend out. – paulo-m Apr 27 '23 at 12:23
0 Answers0
