This is a highly debated / discussed topic, but pretty much all of it based on parts of the country with relatively very high humidity.
I live in San Diego, where humidity is moderate most of the year (60 - 80%). Due to grading issues my crawlspace gets wet during rains. I have decided to do a French drain, sump and vapor barrier.
Question is: will a few ventilation fans in the existing vents (and seal the rest) suffice to control humidity in my area? Or should I seal of all the vents and put in a dehumidifier?
I understand it is actually the dew point differential between the outside and inside that matters, but I am unable to gauge what factors could lead to my crawl space having a lower dew point that the relatively low dew point you find in San Diego most of the time.
FYI I don't have an A/C in my house and the heating ducts run through the attic and not the crawl space.
Thank you!
SAS2Python
  • 123
Fans are usually much cheaper to buy and run.
I would start with one or more fans and try it out for a decent amount of time (more than a month) and see if you are happy.
You might want one of those desk/floor fans that move to mix up the air at the opposite end of the exhaust vent.
crip659
  • 22,808
  • 60
The general recommendation here in Sweden is to use dehumidifiers, the reason is that the outside air will be cooled in the crawl space. When hot moist air is cooled, a sharp increase in humidity or, in the worst case, even condensation occurs.
Rsf
  • 192
