The walls on the sides and back of my fireplace are plaster on masonry. How can I attach baseboards to these walls? I tried bonding with HMA but eventually that just peels the paint off.
HMA? Do you mean [hot glue](http://en.wikipedia.org/wiki/Hot-melt_adhesive)? – Tester101 Apr 22 '13 at 19:05
If by HMA you mean Hot-Melt Adhesive, that stuff is for arts & crafts, not construction.
You should be using construction adhesive.
LOCTITE®, LIQUID NAILS®, DAP®, and possibly other adhesive manufacturers offer a molding adhesive.
- 131,097
- 78
- 316
- 608
If HMA sticks the baseboard to the paint instead of the wall, why would these products behave differently? – ArgentoSapiens Apr 22 '13 at 20:14
Not sure, I'm not a chemist. All I know is hot glue hardens and becomes brittle over time, where as construction adhesive does not. – Tester101 Apr 22 '13 at 20:20
It could be the hot glue interacts with the paint in a strange way. I do know I've used Liquid Nails on baseboard in a similar situation (drywall over [one course concrete blocks](http://i.imgur.com/HpZDATi.jpg) - in case you're wondering why I didn't use strapping) and never had a problem for the 4+ years I lived in the house. I'd also suggest doing this with a proper construction adhesive, and if there's still a problem, come ask about that. – gregmac Apr 22 '13 at 20:55
Thanks for your opinions. I've had only terrible experiences with construction adhesive so I'd like another option. In fact, my experience is the opposite: I've seen EVA (same substance as HMA) stay pliable after 30 years of outdoor exposure in direct sunlight and construction adhesive hard and brittle after <5 years indoors protected between layers of construction materials. – ArgentoSapiens Apr 22 '13 at 21:12
I agree with using adhesive designed for the job. Test some different products with scrap if you are concerned about performance. – ryanwinchester Apr 23 '13 at 03:13
Paint difficulties can be resolved by scraping and priming with a shellac or oil based primed. I prefer the polyurethane based construction adhesives for strength and toughness. Their down side is cure time (overnight)
Another scheme would be to cut back the plaster to 75% of the baseboard height with a diamond blade in an angle grinder (yes, very messy: floor to ceiling tarping, shop vac.. ) Then place 1x or thicker wood and blue screw (one brand of masonry screws are blue and need only a pilot hole (also comes in counter sinkable flat heads))(Tapcon brand, GRK and Spax are also good) it to masonry. Overfill with setting joint compound to flush surface. Nail baseboard normally.
Not afflliated with either company. Have used both.
- 12,104
- 1
- 19
- 37
2PL Premium is like the duct tape of the adhesive world. (i.e. I use it for everything). +1 for polyurethane! – ryanwinchester Apr 23 '13 at 13:30
What does "*blue screw it to masonry*" mean? Also, pictures make everything better ;) – Tester101 Apr 24 '13 at 11:59
1I agree with everything here - except I would definitely apply pressure to the baseboards until they cured - at least 12 hours. – DMoore Apr 24 '13 at 15:54
