House was built in 1964. Slab is about 3 feet across. enter image description here
oilers128
  • 369
Most likely access to a septic system, or sewer sump.
Impossible to say for sure without gathering some hefty help and picking it off, or consulting old documents about your house. It covers something and was evidently meant to be findable and removable, but not easily removable (don't want kids falling in whatever it is.)
Or, the mid 1960's being what they were, perhaps there's an old fallout shelter under there ;^)
Standard Warning to not so much as stick your head in to whatever is under there without thorough venting, though you probably would not be so inclined for the most likely case.
If it's an actively used septic system, go ahead and have it pumped out, since that has obviously not been done in your memory.
My guess is its a Concrete Septic/Cistern cover. Try lifting it up, there may be a tank underneath...
    If it's about three feet across, it probably weighs around 250 pounds. Lifting it could be a bit of a challenge. – Mark May 04 '23 at 02:37
    @Mark The two lifting points are clearly intended for it to be hoisted mechanically. An enterprising backyard engineer could no doubt rig up something, but the original intention was probably to use a backhoe. – Graham May 04 '23 at 08:24
    2-4 burly septic service persons and a couple of hooks (or long bars) would do it. This sort of thing is specifically intended NOT to be easily moved by one person, with the intent of keeping curious children out. – Ecnerwal May 04 '23 at 12:03
