My cabinet door became damaged as my sister put all her weight on it to pull herself up :-)
Repairing the door is very tricky as these cabinet doors are on the kitchen island and the particle board panels they attach to are very thin (only 6/8 of an inch thick) and in addition, any repair on the outside part will ruin the look of the island. The hinges on the door side are in good order, and the paneling that needs repair is the one on the island piece.
Our handy man attempted a repair putting epoxy glue or something like that and this lasted only a year and has fallen apart once more (pictures show the white glue-like substance attached to the paneling and the hinges).
Any help would be greatly appreciated. Would the technique of toothpicks and carpenter glue work on cabinetry that isn't real wood but particle board?
Cecilia
  • 49
  • FYI: 6/8 of an inch = 3/4 of an inch. – Tester101 Apr 23 '13 at 18:35
    It's also 12/16 if you want to go that way. – Chris Cudmore Apr 23 '13 at 18:56
  • Wood glue and toothpicks will probably only be another temporary fix. – Tester101 Apr 23 '13 at 19:26
  • Can I see a picture of the door? or even the inside of the good door. You have some odd hinge locations. No matter what this is repairable thought. – DMoore Apr 26 '13 at 05:30
    At worst you can relocate the hinges by a few inches. – RedGrittyBrick Apr 26 '13 at 09:30
    @RedGrittyBrick: Relocating hinges is usually very hard - the part on the door is hidden inside a cylinder hole that needs to be routed and is very hard to do without a router. – sharptooth Apr 26 '13 at 12:28
  • Just curious, what's the shiny flexible pipe inside the cabinet? – sharptooth Apr 26 '13 at 12:31
  • @sharptooth The shiny flexible "pipe", is Type AC/MC cable. It looks like it's supplying a receptacle outlet on the side of the island. – Tester101 Apr 26 '13 at 13:08
  • @Tester101: Wow. Where I live if one wants metal shielding he uses metal hose around the cable. And doing so inside a kitchen cabinet is not a usual practice. – sharptooth Apr 26 '13 at 13:23
    @sharptooth: In rightpondia, if you have an ordinary electric drill, a ruler and a pencil, for the equivalent of $10 you can buy a hole-cutter for the purpose. [example](http://www.wickes.co.uk/hole-cutter-for-35mm-hinges/invt/500586/). – RedGrittyBrick Apr 26 '13 at 15:43
  • @RedGrittyBrick: That would work for through holes, but not for the hinges - those require holes of exactly the right depth and will completely even bottom and that requires a router. One minor deviation - and the panel is cut through and that's a permanent damage. – sharptooth Apr 29 '13 at 06:20
  • @sharptooth: Sure there's potential for mistakes, and it's prudent to practice on scrap wood. But, if you look at the picture on the product in my answer, it's designed for exactly this job. You don't need a flat bottom of precise depth when using the hinges found in the EU because, as well as the circular section, they have flanges that hold the hinge flush in the door (see picture). – RedGrittyBrick Apr 29 '13 at 09:10
Plan A) I'd try to remove the glue, fill the holes†, let it set and then re-drill the holes
Plan B) Use repair plates designed for this job Example
Plan C) If all fails I'd spend $10 on one of these, put it in my old electric drill's chuck and relocate the hinges.
† Using maybe something like an "Interior Wood Filler that holds screws and nails".
RedGrittyBrick
  • 24,201
  • 47
This is certainly fixable, although not a trivial thing to do.
Option one is trying to use the same holes. You can use plastic concrete anchors that are used to drive screws into concrete. You'll have to drive the anchor into the hole and cut off the remaining part. Then you can drive a wood screw into there and that will secure the hinge. I tried this once. I guess you'll have much better results if you apply glue to the anchor surface and let it dry before proceeding so that the anchor is better held in the panel. The key is you use an expandable anchor - one that expands when a screw is being driven in.
Now suppose that it doesn't work because the particle panel has incurred much damage and you can't repeat the original assembly. So the solution is to attach the hinges in slightly different way. Here's a drawing for a single hinge (description follows)
Here 1 is the inner surface of the cabinet, 7 is your hinge - the hinge will go unchanged.
2 is a steel plate - you can get those in a local hardware store, they are typically used to connect the drywall framing parts together, they are typically 2-3 millimeters thick and can have a variety of sizes, you need something like 50 by 50 millimeters or larger so that it fully covers the damaged area and you can drive wood screws 3 and 6 into the cabinet panel to reliably secure the plate. I only show two screws here, but you'd better drive four - one near each corner of the plate - or more.
Then come 4 and 5. Each of them is a plain old threaded screw or bolt in pair with a matching nut. You'll have to pass them through the holes in the hinge that were previously used to attach the hinge (to now wrecked panel) and through holes drilled in the plate and drive a nut from the cabinet surface side. The nuts will likely fit into the holes of the panel, otherwise you'll have to cut some for them.
If the door now closes - great, that was the easy scenario. However you may find that because the plate has some width the door will no longer close. If adjusting the adjustment screws on the hinge (of both doors) doesn't help fix that you'll have to mortise the plate into the panel to compensate for the plate thickness which is not an easy thing to do but can be done using a router (most recommended), a chisel (less recommended, still doable), or a Dremel-like tool (not really recommended).
sharptooth
  • 9,537
  • 62
  • 87
    Expanding anchors won't work in particle board at all well. Worse, they are not designed to go into a thin board, which that island wall is. –  Apr 26 '13 at 18:50
  • @woodchips: That's not a big problem. The anchor has to be force-hammered and then it will compact and will hold the screw quite well. So yes, you're right that it won't work the same way as if it would work in concrete, but it will work in another way. – sharptooth Apr 29 '13 at 06:17
