I need some clips that fit on the ends of rods that look like: clips
Do they have a more common name than 'omega clips'? I can't find much if I search for that name.
EmmaV
  • 189
    They are a bit odd, so not surprising you find limited results. **C** or **E** clips are far more common in my experience for this job, particularly if the rod has a groove in it. Or cotter pins that involve a hole though the rod. – Ecnerwal Jun 01 '23 at 12:16
  • *spring clip* ... https://www.mscdirect.com/industrialtools/spring-clip.html – Mazura Jun 02 '23 at 00:38
  • It's kinda like an E clip but they're made from pressed sheet metal, not wire. So that's not correct. – Criggie Jun 02 '23 at 12:00
Omega clips is pretty much what they are called and googling it came up with this. https://www.bresco.com/acatalog/Omega-Clips.html
JACK
  • 78,739
  • 72
  • 188
Ultimately, they are Cotter pins in the US. A true cotter pin is straight, though, so they are often put in the subset of Hairpin Cotter pins or just Hairpin.
I see that Home Depot also calls them Hitch pins.
Kurt Granroth
  • 850
