I had this unit put in about 3 years ago and have had so many issues with thermostats. Can someone help me identify where to place the c wire? It is available behind thermostat but not plugged in. Thank you so much
UPDATE: The pictures I posted originally showed C hooked up, but I came to find out that was actually Y, and I moved it to the correct terminal. I now need to know what transformer to connect the back of C to, and do I need to add the wire or should it be somewhere in front of me for me to simply plug in? Thank you for all your help
