I modified the outlets on a solar hot water tank, and now it leaks.
The leak occurs between the brass fitting on the bottom (Edwards hot water) and the short pipe below. I don’t know what sort of connection it is.
If I don’t get any ideas, I will assume that the edwards fitting has an internal screw; and take everything apart to Teflon tape this.
This happened because I added another brass T piece for another hot water outlet.
Polypipe Wrangler
  • 1,458
0 Answers0
