I recently purchased a new microwave and it has arrived with a European 2 pin plug which states on it 16A 250V. The microwave panel and instructions both state 230V. How can I safely use this on our UK 3 plan plug sockets? I have seen videos cutting off the plug and re-wiring a UK plug to it. But I worry this would void any warranty.
Richard
  • 51
    New stuff that does not meet expectations should be sent back. See the maker to see if those microwaves come with a UK plug. The third prong is for ground connection and needs a three wire cable to work. The microwave will work, the ground connection will not. – crip659 Jun 28 '23 at 13:59
    Send it back! Send it back! Send it back! Send it back! Send it back! – FreeMan Jun 28 '23 at 15:07
    Thank you for the advice. I called customer service and they said they will send a replacement out with the correct plug. We shall see in about 2 weeks or more probably…. – Richard Jun 28 '23 at 15:58
    @Richard the sellers who make that mistake are often shipping cheap garbage from China, which lacks any of the mandatory safety certifications. Note that CE is *widely faked*, and the EU's only recourse when that happens is to threaten their bricks-and-mortar assets inside the EU. Many mail-order sellers, their only physical presence inside the EU is a mailbox at a mail forwarder. – Harper - Reinstate Monica Jun 28 '23 at 19:03
  • Edit queue: s/plan/pin/ – Criggie Jun 29 '23 at 02:34
  • Bold of you to presume there is a warranty, if this is mail-order stuff. Sorry. – Criggie Jun 29 '23 at 02:35
    Is it really a 2 pin plug or a shuko, which has a contact that's very flat, on both sides, and is used differently in france and germany IIRC? – Journeyman Geek Jun 29 '23 at 08:30
  • If you bought it on Ebay, then I would suggest that you will never see a replacement. Out of a score of bad purchases, only one sent a replacement, because I posted a bad review. Others relied on the time period on Ebay for complaining to expire - using false promises. – Rohit Gupta Jun 29 '23 at 12:05
  • @RohitGupta - Likely depends where you live, but in the UK once a complaint has been raised with the seller, you've triggered a resolution process, where the *seller* is then under legal pressure to act, which means the dispute cannot time out on your end. [Also a good reason to always use PayPal, who will intervene on your behalf if things go pear-shaped.] – Tetsujin Jun 29 '23 at 13:02
It's against all regulations to sell anything electrical in the UK without the correct plug.
Send it back.
You can't just change the plug yourself because a microwave must be earthed.
If you bought it from Amazon, eBay etc report the seller.
Tetsujin
  • 10,454
  • 37
    Thank you for the advice. A replacement is being issued apparently… only time will tell if they do what they have said. – Richard Jun 28 '23 at 15:59
    I agree with you that exchanging the equipment is the best course of action, but it's possible to replace the plug safely. A European 16A plug only has two _pins_, but it has an earth connection at each side (plus a socket for the earth pin in the French version). The UK adopted the European colour code for flexible cable in 1971, so there's no problem with identifying the wires. – grahamj42 Jun 28 '23 at 22:32
    @grahamj42 Only some European 16A plugs are earthed. If it’s a CEE 7/7 (most likely), CEE 7/6 (unlikely) or CEE 7/4 (also unlikely) then it is indeed earthed. A CEE 7/17 plug _can_ be rated for 16A, and is _not_ earthed. I would not expect to see one of those on a microwave though, but it’s theoretically possible. – Austin Hemmelgarn Jun 28 '23 at 22:39
  • @AustinHemmelgarn for a new microwave I consider it extremely unlikely that a CEE 7/17 would be fitted, even with a fake CE-marked appliance. – grahamj42 Jun 29 '23 at 05:55
    @grahamj42 - I hadn't actually considered that; but the more important aspect is the seller realise they just cannot do that in the UK. A UK plug *must* be fitted. If the OP tries to change that themselves [& appears to not be well-versed in this, so I wouldn't recommend it anyway], then the seller can claim a void warranty, whereas right now the customer has every right to demand a correct appliance or money back; and now the claim has been raised, they get 6 months rather than just the regular 14 days. – Tetsujin Jun 29 '23 at 08:36
You could buy a good quality adaptor to plug the European plug into a UK outlet. Make sure it has a 13A fuse fitted, and that it uses the earth connection.
Avoid all cheap travel adaptors, especially the universal types that will allow you to plug in any plug from anywhere in the World.
Simon B
  • 3,758
    Note that typical "travel" adapters are not approved for permanent use in the UK. But you can buy permanent adapters which screw closed over the Europlug, and these are legal for permanent use. But as the other answer says - the seller needs to sort this out. – Jack B Jun 29 '23 at 14:59
  • The 'permanent' adapters would likely not be capable of taking the power the microwave takes - could be 5A or more. They're typically only for low power things like electronics. The Europlug is only rated to 2.5A so it seems unlikely the microwave has one, more likely a full size Schuko or similar. – user1908704 Jun 29 '23 at 16:13
Assuming sending it back isn't an option, you would need to use a suitable adapter, which is rated for carrying the current the microwave would take. Most travel adapters are not rated for carrying many amps, but other extensions are: Plug extension (source: Amazon) 4 way extension (source: Amazon)
(by no means an endorsement of these specific products)
Another option is to buy a trailing socket of a suitable type (eg the 4-way Schuko lead shown here), cut off the plug, and attach a UK plug to it. This is often cheaper if you can pick one up when in a country that uses the Schuko plugs.
user1908704
  • 1,212
