So basically, I want to make a desk that is 8 feet long of MDF with a veneer top and hardwood trimming, I haven't worked extensively with MDF before and I have read a lot complaints about sagging over time.
My current design is 24" x 96" MDF that is two 1/2" thick slabs of MDF glued together with two 8 foot steel .75" square 16 gauge rods running up and down the length.
Will this sag length or width wise?
David
  • Or this? [How can I support a desk without legs or brackets](https://diy.stackexchange.com/questions/49153/how-can-i-support-a-desk-without-legs-or-brackets) – isherwood Jul 02 '23 at 13:03
  • Or this? [Will a 72 x 24 x 1 3/4" Maple tabletop sag if supported by only four legs?](https://diy.stackexchange.com/questions/188972/will-a-72-x-24-x-1-3-4-maple-tabletop-sag-if-supported-by-only-four-legs) – isherwood Jul 02 '23 at 13:04
  • Or this? [How to "float" a large desk (3000mm x 720mm x 40mm) between walls](https://diy.stackexchange.com/questions/101288/how-to-float-a-large-desk-3000mm-x-720mm-x-40mm-between-wall} – isherwood Jul 02 '23 at 13:06
  • Try the [sagulator](https://woodbin.com/calcs/sagulator/). I tried it with some hand-waving because it doesn't allow for steel reinforcement. And it's a guide, not authoritative. But it looks like you'll get a little sag, if you put a monitor, keyboard, and a few books on it. If you sit on it, it'll be frightening. – jay613 Jul 02 '23 at 13:57
  • Just out of curiosity, is there a reason you're doing it this way? Poor materials, saggy, soggy, and you're using two sheets and gluing them together ... And then adding steel, it sounds like a lot of work, a lot of money, I don't get it. – jay613 Jul 02 '23 at 14:01
An 8 foot long 3/4" steel rod will sag, rather dramatically, all by itself.
The same amount of steel in a different shape (tubing or angle, typically at this scale) would be much stiffer. As vaguely described, (I can't tell if you are putting the steel between the layers, beside them, or under them from your description) your desk will still sag.
A far stiffer basic slab structure is to build a "torsion box" with thin skins and lightweight spacers between the skins. It also happens to end up a lot lighter than a solid hunk of MDF.
It will be very heavy and the strength comes from a supporting structure, not from the MDF. I would make the frame out of timber and then line it with MDF if required. And you always have to worry about the MDF coming into contact with water and turning into breakfast cereal.
This is from my experience in building couches for ourselves when we purchased our first house. We could not afford to buy carpet or furniture. So I built it as above. It was extremely heavy. And it lasted for over a decade until we had a house fire when it turned to mush from the water used to put it out.
Rohit Gupta
  • 5,090
    Is water a big concern for a *desk* covered with veneer and hopefully some kind of finish? – jay613 Jul 02 '23 at 13:26
I suggest you stop by the steel store and give that bar a sit. In other words, if it doesn't support your weight fairly effectively at the center of an 8 foot span it's not suitable for a desk of similar length. You'll find that not only is 3/4" square rod heavy, it's quite flexible. With steel, as with any material, shape matters. You need height, not weight.
Take a look at the many desk discussions on this site. The nearly all have this same flaw in their designs. You either need intermediate support from a wall, or substantial longitudinal beam structures. Consider a bed frame as a reasonable guide. Most have either 2" steel angle or ~6" wooden side rails, if not legs in the center.
