Currently, the switch turns the entire outlet off or on for a garbage disposal. I'd like the top outlet to always be on and the bottom to be switched for the disposal.
The outlet has a white wire and black wire, on different sides (see image below). Do I just break the tab off the silver screws side? Do I need to wire it differently?
** EDIT - what I ended up doing was just using a smart outlet, Wemo Smart Plug, on that outlet below the sink and plugged the disposal into that, rather than running another wire down there to make it an actual half-hot outlet. **
