I had a single 20amp outside breaker with one red and one black wire connected to it. it kept flipping. i had unused double 20amp breaker. i put red wire in one spot and black wire in other of double 20amp breaker. is that safe or not
Leeza
    Why does it keep flipping? When the breaker trips, what loads lose power? Are you talking about a [tandem](https://diy.stackexchange.com/questions/110151/what-is-a-tandem-breaker-aka-duplex-cheater-twin-double-stuff-etc) breaker (because no, that is not safe at all). – Harper - Reinstate Monica Jul 06 '23 at 02:28
    A picture of the panel and a list of what loads are currently powered by the circuit would help. – manassehkatz-Moving 2 Codidact Jul 06 '23 at 02:49
    Do the red and black wires lead into the same cable or different cables? What are you trying to run on the circuits in question? What do you mean by a "double 20A breaker"? – ThreePhaseEel Jul 06 '23 at 03:39
Man oh Man>>>>>> no way. I don't do be mean, but you obviously have no idea where these cables lead or how they are connected , could be a MWBC could be an repurposed cable....you just can't know until you test and test some more until you know where this stuff goes. you'll need a multi-meter and test that circuit thoroughly . Regularly tripping a breaker is a major issue and and dangerous . You may need to call a pro.
George Anderson
  • 23,066
  • 35
  • 79
    Well regularly tripping a breaker may be as simple as the user intentionally overloading it because they want more stuff to work than the circuit can safely power. – Harper - Reinstate Monica Jul 06 '23 at 02:39
    And it may be that the red/black used to be two separate breakers and now doubled up under one breaker and separating is a *good* thing. Or it could be something else and separating could end up with causing all kinds of problems. *Too many unknowns*. – manassehkatz-Moving 2 Codidact Jul 06 '23 at 02:49
