Our brick chimney is leaning away from our house. The breast is in the living room, pretty much flush with the wall. The backside starts in the attached garage, goes through its roof and up past the second floor house roof.
We are thinking of removing it to below the garage roofline so we don't have to deal with the living room at this time. We also have a metal roof very much like this but not as steep:
The chimney basically goes through the peak of the garage roof, although not quite centered.
I expect we'll need a roofer and someone else to patch the vinyl siding (there is none where the chimney used to be against the house.
What kinds of things should I expect? Cost (understood to be very general), approach (hopefully not throwing the bricks down the chimney), damage to roof besides closing the hole, or anything else to watch out is what I'm after.
Andy
  • 220
  • I understand the chimney is having issues. Do you not want a chimney? Also the picture doesn't show the chimney well. – DMoore May 08 '13 at 05:26
  • We can't possibly give you a cost, as that'd be incredibly variable. The approach is typically tossing the bricks down, though. – DA01 May 08 '13 at 05:32
  • If you don't want to drop the bricks down the flue and remove them from the bottom, build a wood slide out of plywood and 2X4's down the roof, so bricks will fall to the ground in a safe place and not damage the roofing. – shirlock homes May 08 '13 at 09:37
  • @DMoore It has other problems as well, such as not being secured to the house at all, and the fireplace itself would need work. It's more of a hassel. And that picture is not of my house, its just a very similar looking garage and seems to have the same exact metal roof (oddly). – Andy May 08 '13 at 16:22
  • @shirlockhomes Ok, I'll be sure and find someone that is willing to do that to avoid damaging the roof. Its only four years old. – Andy May 08 '13 at 16:23
  • @DA01 I was thinking a range, understanding that it could be a huge range, but something more than between $1 and $100 million... I can edit that part out if its a problem. – Andy May 08 '13 at 16:24
  • Taking it down... It can be a DIY. Fixing every room it touches is a HUGE mess. If you like the idea of a fireplace but don't like the idea of your slanted fireplace.... then I would call a fireplace company and see what it would cost to install a straight/new fireplace system. By the time you fix every room in your house that the fireplace touches you might be getting to buying a new fireplace. – DMoore May 08 '13 at 16:27
  • If the fireplace used to be against the house and now its leaning away (and documented to be tilting more) you may have foundation issues that are larger than just your chimney. – Dopeybob435 Sep 27 '13 at 20:54
  • @Dopeybob435 I haven't seen any indication of foundation problems. A chimney inspector said if it didn't remove it that could cause them. – Andy Sep 28 '13 at 00:17
We were able to find someone to do this. They removed part of the roof on the garage and built a ramp over the ply wood to toss down bricks. They removed it to below the roof of the chimney and patched the hole in the roof and reinstalled the metal panels. They also put siding on the house where the chimney was.
No mess in the living room and it was about a fifth of the price of a teardown and rebuild, approx. $2300. This is in New England, so price might vary. Also, the foundation for the chimney wasn't done right when built, which is why the rebuild price would have been so high.
Andy
  • 220
Just in case someone else looks at this I will add an answer since Andy's answer seems a little off.
First to tear down a chimney is about $1000 in the US. There is siding, roof, and other repairs that have to be made. Not sure what Andy had going on since we never got a picture. $2500 might not be way off if they had to do a lot of things after the tear down.
Why I am writing this is the quote on the new chimney. You will still have to pay about 1K to tear down (and this is a definite DIY deal) and break up footer (if you need to). Not rocket science. The hardest part is getting rid of the bricks after.
The cost of materials really depends on what you want. But a 30 foot chimney can be made with 600-800 in materials and might average around 1500. Mason will cost on the low end $1000 and high end $2000 - extra $200-300 if you make them pour the footer (another easy DIY). The mason I have used charges me $1200 and he is done in 2.5 days.
So if you do the easy DIY things you are at 1500 in materials and 1500 for mason - so a good medium to high estimate is 3K. Add another 1K if you don't want to do anything.
DMoore
  • 47,764
  • 190
  • "The hardest part is getting rid of the bricks after" = I found it in credibly easy to get rid of bricks. Posting "free bricks, you haul" on craigslist usually brings out many people wanting them for garden pavers and the like. – DA01 Sep 28 '13 at 06:19
  • The garage has a steel roof and a new panel had to be installed because the old one had been cut to accommodate the chimney. They also did the siding. I'll add more pictures. – Andy Sep 28 '13 at 19:53
  • @DA01 - Yes for bricks. Not for bricks with mortar attached. – DMoore Sep 29 '13 at 04:06
  • Andy not saying $2500 is a bad price at all. Was more on the 12.5K quote for a new one. If you have an old one everything is already framed out. – DMoore Sep 29 '13 at 04:07
  • @DMoore The foundation for the chimney was built incorrectly and it could have caused foundation problems with our house (we have a basement but the bulk of the chimney was in the garage adjacent to where the basement is). It was closer to 10k for a rebuild, my numbers in this question were approximations, sorry for the confusion. – Andy Sep 29 '13 at 14:03
    @DMoore I suppose it depends on region. I had people clamoring for my mortar-encrusted pile of bricks. – DA01 Sep 29 '13 at 16:07
