I have 2 Ikea wardrobes units, each in a corner. There's about 9" of empty space above them, which I want to close off so the units run smoothly to the ceiling. I was thinking of adding a simple wood frame to the top of each unit (I can't drill into the ceiling) and attaching either 1/2" drywall or plywood. Is there a reason to choose one material over the other? Or can someone suggest a different, better approach? Some possibly-helpful info:
- My walls are plaster and probably a little uneven.
- I plan to add crown molding, so I'm not concerned about the drywall/plywood fitting perfectly against the ceiling.
- I plan to paint everything, so I don't need to match the laminate color (and there's no benefit to using melamine as suggested in this answer).
Thanks so much for any and all help!
