I think we have a clog of dried soap in our pipes, past the U-bend and down the pipes from upstairs to the drain at ground level.
How do I clear them?
Nikki myers
  1. Moving water, preferably hot. If you can get a small flow that doesn't back up then it will dissolve away easily.
  2. Environmentally safe degreaser/cleaner, I prefer Simple Green
  3. Baking soda and vinegar, it will clean almost any small clog. With something that dissolves easily like soap, the extra air bubbles produced will help getting it clean with less passes as well.
Jason
  • 2,051
  • I have tried all of these but we still get an overwhelming smell of soap in the house that makes it difficult to breath easily, not sleeping unless windows wide and cold airflow in house. – Nikki myers May 11 '13 at 09:16
    It sounds like you have some other issues then, if it is past the "U-bend" or p-trap then it should not affect any smell inside the house. If somehow it is, then you have larger issues as it means you are also leaking sewage gas into the house which - aside from smelling way worse than soap - can easily make people sick. – Jason May 12 '13 at 12:12
I would skip all the chemicals and just use a drain auger on it to clear the build up. After you break through then you could probably rely on hot water to clean anything remaining out.
Auger
(source: homedepot.ca)
Glorfindel
  • 1,173
Steven
  • 27,594
  • 53
  • 88
I know I am replying to an old post but I have relative info. My mother has a soap shop and her lines backed up with soap after the P trap as described in this post. Imagine soap in your hands in the shower, soap is hard and even when submerged in water over long periods of time doesn't become soft enough to lose its structural integrity. Hot water won't suffer it any different or even acids. If you put all that down your drain you then have an impact of soap with dangerous liquids on top not doing anything. The ultimate outcome was to cut the lines and manually blow out the soap with an air hose. We tried all the methods above and when I cut the line the soap and then all the dangerous liquids rushed out into my working space. What I learned from this, don't put harmful ingredients or spare soap or hot pour soaps down the drain. Simple as that. If you do you ruin your drain lines.
ps. Augers will not work. They will bust up the soap yes but then the pieces will travel further down line and clog again.
Jake
Any of the below options are good for a start without a more specific problem
  1. Mo-flow drain acid (made by Momar)
  2. Caustic Soda
  3. Boiling water
  4. Drain Eel
  5. Draino
UNECS
  • 1,348
Option 1: Mix 1 cup baking soda, 1 cup salt, and 1 cup white vinegar. Pour it down the drain and wait 15 minutes before flushing the drain with hot water.
Option 2: Drain gun from your local Home Depot.
Option 3: Drano(sodium hydroxide, sodium nitrate, sodium chloride, and aluminum).
Chris
  • 116
