We have a very small lot and are trying to squeeze in a parking space as best we can. The best option for us seems to be a 9x18 space that is parallel to the street. I have made a rough diagram.
There is a gate that runs the whole length of the space, that we are planning to turn into a sliding gate where the 9 ft section to the right slides open. Unfortunately, it needs to open right to left, vs left to right, which seems like it may have been better given traffic direction.
We have gotten approval to do this. My question is, this seems to be enough space to park in a vacuum, but will we actually be able to get a car in an out of the space?
Rohit Gupta
  • 5,090
KD35
    Go to an empty parking lot and mark out the corners and limitations of your space with traffic cones and see if you can maneuver into the spot (including the 9' entrance limitation) with your chosen vehicle. That will tell you if it's possible. Anything else is just guesswork. To me, it seems way to small for most vehicles (especially with the 9' entrance limitation, but without knowing what type of car, it's impossible to say for sure. – Milwrdfan Jul 22 '23 at 03:28
  • Realistically only for very very small cars. The biggest question is how busy is the road. – DMoore Jul 22 '23 at 06:02
    You need a cleverer gate design. I'm pretty certain there are multi-section sliding gates that allow nearly 2/3 of the gap to open, maybe even nearly 3/4 in 4 sections. Or no gate at all, which is common here but not the done thing everywhere – Chris H Jul 22 '23 at 08:52
  • Is the gate a security gate, or just a barrier to keep people from parking in your space? – Huesmann Jul 22 '23 at 12:13
  • There are gates that slide *all the way out of the way* (like a garage door turned sideways), but probably a 4-section one that collapses to 1/4 of the space would be adequate - depending on vehicle size. With that gate design, your parkable vehicle options are quite limited (but perhaps you wanted an excuse for a motorcycle, perhaps one with a sidecar, so there's that.) – Ecnerwal Jul 22 '23 at 12:47
  • If OP really wants a gate, it will need to be one that gets almost completely out of the way. If it's just to stop people from parking, a chain might make more sense. – KMJ Jul 22 '23 at 18:37
For nearly all cars, I expect the answer to be No, this parking spot will not be usable as currently described. For this example, I've used a 5-door Kia Rio, generally considered a small car. It is drawn to scale below, excluding the mirrors. I drew your spot to scale with the car, including with a gate opening half of the spot. It doesn't allow the car in. You cannot achieve the angle needed to make it between the gate and fence without hitting one or the other.
car and spot to scale
If you use a very small car this can work. Barely. Here is the same drawing with a Mitsubishi Mirage, the smallest car currently for sale in the US. Parking this will be an incredible headache, but it's possible. You'll likely scrape from time to time unless you're an absolute expert driver.
mirage scale drawing
If the car can temporarily exceed the bounds of the parking spot, say if there's a walkway next to it that can be temporarily blocked during parking maneuvers, this will work slightly better and perhaps allow a bigger car such as a MINI to park there. It will still be incredibly tight.
If you come up with a gate that opens wider, to say two-thirds the width, parking a few more cars becomes possible. It will still be tight but won't need quite the perfection of the above plans.
If you remove the need for a gate, so it's just an open spot, it becomes almost trivial. It's an ordinary parallel parking spot at that point. Parking in it will be quick and easy with a bit of practice. Most midsize and smaller cars will fit just fine.
Oh, and just for giggles, here it is with a Smart Fortwo. With a car like that, parking in this spot is easy.
smart parking to scale
Note that all of these scenarios will require you to back in, parking in a parallel parking style, to have any chance of success. Trying to go nose in will not work. If there is a gate that stays partway in the way, it must open right to left. Otherwise you will be trying to parallel park facing the wrong direction to traffic, which sounds awful. The only vehicle that will make it in nose first is the Smart.
KMJ
  • 9,197
  • 40
