15
We bought this house 4 years ago and the kitchen was updated by the prior owner about 7-8 years ago. The Fridge is about 12-13 years old and has been acting up. I started looking at replacements and measuring out our current fridge and its 36" x 36".
The two exits to the kitchen are 32" and 31.5" respectively. Meaning they remodeled the kitchen with the fridge in place and added cabinetry and a countertop that essentially imprison the fridge. Even with the doors off. the fridge only drops to 33" x 36"
My inclination was to just take a reciprocating saw to the fridge and curse the prior owner for making me have to get smaller fridge. But, then googling seems to say that's a bad idea (saw is going to bounce around a lot/likely to puncture something with the refrigerant and have it blast off into the house). So I'm at a bit of a loss about how to best handle such a predicament.
Rohit Gupta
  • 5,090
D_D
  • 159
  • **Comments have been [moved to chat](https://chat.stackexchange.com/rooms/147498/discussion-on-question-by-d-d-how-can-i-remove-a-fridge-thats-trapped-in-my-kit); please do not continue the discussion here.** Before posting a comment below this one, please review the [purposes of comments](/help/privileges/comment). Comments that do not request clarification or suggest improvements usually belong as an [answer](/help/how-to-answer), on [meta], or in [chat]. Comments continuing discussion may be removed. – Niall C. Jul 28 '23 at 04:07
Assuming cased openings, temporary removal of your door jamb should get you there. It's often a matter of removing the casing and detaching one or more sides of the jamb. If you're careful it'll all go back on with little indication that it was ever off.
For more detail, give us more detail.
    OP may also want to double-check that the kitchen doorway is the only bottleneck. It would be maddening to go through the effort to open up the doorway, only to discover that the front door or the hallway to the kitchen were too narrow as well. If it were my house and I was going through the trouble of removing door casings or jambs, I would seriously consider if it would be possible to permanently widen the door opening before reinstalling the trim. A 32" door just isn't big enough for my tastes. – spuck Jul 27 '23 at 15:07
15
Repair the refrigerator and then forget about the door problem for another several years.
The idea that newer appliances use less power than the older ones is overblown, if not outright false. Recycling the old fridge costs energy and it probably won't be fully recycled anyway, meaning landfill. The manufacture of the new fridge also costs energy, meaning pollution. And newer appliances have a reputation of not lasting as long, costing you more money in the future. Happy Earth Day. I'd repair it until it can't be.
Source: I have repaired appliances for ~40 years.
Toby Speight
  • 355
kackle123
  • 383
    Especially if the fault is something minor like a relay or thermostat. – UmH Jul 27 '23 at 05:07
    "The idea that newer appliances use less power than the older ones is overblown, if not outright false." The latter even has a name: "[planned obsolescence](https://en.wikipedia.org/wiki/Planned_obsolescence)". – Trang Oul Jul 27 '23 at 09:50
    Fridge is one of the few appliances that may be worth replacing for efficiency, because they operate continuously for long periods. According to the specs (I really should measure!), my new fridge was expected to repay its purchase price in under ten years (and probably faster than that, since energy costs have outstripped general inflation). Although I'm not claiming that financial cost exactly represents energy use, it's often the primary motivation as a householder. – Toby Speight Jul 27 '23 at 13:15
    "The idea that newer appliances use less power than the older ones is overblown": Quotation needed.This [MIT paper](https://web.mit.edu/ebm/www/Publications/MITEI-1-a-2010.pdf) from 2010 estimates the energy needed to produce a fridge in the single-GJ domain while the usage lifetime consumption is in the dozens. Based on that, the energy production debt would be payed off if the new fridge were perhaps 15% more efficient, which is realistic. Obviously, the footprint of the consumed energy is paramount: If you have your own solar panels you should keep your old fridge. – Peter - Reinstate Monica Jul 27 '23 at 13:40
    @TrangOul, I believe that much of what's credited to planned obsolescence is actually just due to simple economics and marketing--the cheaper product sells better, resulting in an endless decline in quality of nearly everything. To attribute it to some grand scheme violates Occam's Razor. It's just a side effect that it appears that way. – isherwood Jul 27 '23 at 16:02
    @Peter-ReinstateMonica, are refrigerators getting more efficient that quickly? I replaced my 40-year-old refrigerator rather than fixing a stuck switch because of the dramatic efficiency improvements, but I don't recall any such changes in the past decade. – Mark Jul 27 '23 at 20:31
  • @Mark You have to look at the individual model and it's power usage rating. – Karl Jul 27 '23 at 21:26
  • @Mark The pace of efficiency gains is certainly slowing down, at least in absolute terms (because the improvements in the last decade are from an already pretty reasonable baseline). Since absolute terms are what counts here, there are certainly increasingly diminishing returns from replacing fridges (since the production/usage energy ratio is leaning more towards production). But the OP's one is a bit older than 10 years. And of course chances are the old one is of average efficiency while the new one can be top efficient which gives an extra bonus. – Peter - Reinstate Monica Jul 28 '23 at 08:30
    @isherwood producing for quantity, not quality _is_ planned obsolescence. It doesn't have to be a collusion between all the producers. – Trang Oul Jul 28 '23 at 09:35
    @TrangOul But then *every* quality target is "planned obsolescence" because you could *always* still improve quality -- there is no perfect product. Obviously, that is an unremarkable truism and not what is meant by the term. "Planned obsolescence" implies duping the consumer and producing worse quality than could be possible at the same price target in order to shorten product life and thus sell more product. (No collusion necessary, or only implicit one, because in a working market a competitor would produce better quality for the same price and out-compete the fraudster.) – Peter - Reinstate Monica Jul 28 '23 at 12:23
  • @Peter If 15% improvement is accurate, then I'd like to see that in writing. A lower-mass compressor will likely fail earlier, by the way. Even then, that's a number given by the people who are MAKING/SELLING the product, so it is already suspect in my mind. Further, where is the accountability for the pollution, the waste? Should the cost to run it be the only consideration? I know of no one who considers the complete "cost" of manufacture and the environmental impact of disposal. Extra energy savings will not correct pollution or planet poisoning from disposal. My 2 cents. – kackle123 Jul 30 '23 at 19:19
Call a fridge serviceman to come and degas it first. Unless you have a very strong reciprocating saw, it is liable to jump or get stuck as go through varying hardness of materials. Some options
  1. Dismantle it by removing all parts systematically until you are left with a shell. Then you can use a hammer to fold the outer body
  2. Remove all glass and plastic bits, protect your floor with a sheet of particle board and use a sledge hammer carefully.
I would go for 1.
Rohit Gupta
  • 5,090
    Also fridges often use flammable gasses, so venting those in the house while some saw is shredding metal might not be a wise idea. – Martin Jul 26 '23 at 13:38
    This gets the old one out. It doesn't get a new one in. – isherwood Jul 26 '23 at 13:49
  • @isherwood For the new one, find one < 32" – manassehkatz-Moving 2 Codidact Jul 26 '23 at 14:12
    That has several obvious drawbacks. – isherwood Jul 26 '23 at 14:12
  • @manassehkatz-Moving2Codidact I am with isherwood on this one. I think the OP might have to think about enlarging the exits. Today it is the fridge, I imagine they will have the same problem with the stove/oven. – crip659 Jul 26 '23 at 14:26
  • @crip659 at least 30 inch ranges are a thing – KMJ Jul 26 '23 at 14:40
    @crip659 Should not be an issue with *any* other standard US kitchen appliance. All standard US kitchen appliances - wall oven, range (cooktop + oven), dishwasher, trash compactor (don't see those much these days but they used to be a big thing) are designed for **counter depth** which is **24"**. Add a couple of inches for door handles and clearance, and 30" is plenty of room. – manassehkatz-Moving 2 Codidact Jul 26 '23 at 14:57
    The problem is **specifically refrigerators** because to get your typical "family size" 25 cubic foot side-by-side refrigerator [such as this Whirlpool](https://www.homedepot.com/p/Whirlpool-25-cu-ft-Side-by-Side-Refrigerator-in-White-WRS325SDHW/302894884), you end up with 31" - 34" depth. In the old days (and still, with many *non-side-by-side*) you could easily remove the doors because the doors had to be removable anyway to switch between left vs. right opening. Side-by-side don't have that (at best they have removable *handles* which can get you an inch or two of extra clearance, which – manassehkatz-Moving 2 Codidact Jul 26 '23 at 14:59
    can help) because the doors are not designed to switched (different sizes) or to be removed (especially freezer side if it has through-the-door water dispenser). So this is a **refrigerator problem**. A real problem for a lot of people, but specific to refrigerators and not to other kitchen appliances. – manassehkatz-Moving 2 Codidact Jul 26 '23 at 15:01
  • @crip659 we brought a new stove when we moved in the stove is 30" wide so it got in without much fanfare. The DW is 24". I may have to see about a partial remodel or something – D_D Jul 26 '23 at 18:49
  • @D_D the stove is probably only 26" deep. Maybe have to remove the oven door to get to 26", but the oven door very likely lifts right off without tools. – Jim Stewart Jul 28 '23 at 10:13
  • @D_D the doorways into your kitchen really are too narrow to allow passage of the kind of upscale refrigerators that are available in the US. I wonder if one of the European manufacturers (e.g., Miele) would make a narrow refrigerator for the US market but based on a European concept of proper dimensions. – Jim Stewart Jul 28 '23 at 10:23
Depending on the space available in the kitchen itself, and if you have a reasonably large double glazed window, you may find it possible to remove the window pane then manoeuvre the fridge through the window. Obviously this has a lot of caveats and you would probably need a few strong helpers on either side of the window but as a last resort may be possible.
Please note, this would be for removal only. You shouldn't tip a new fridge onto it's side like this.
Tragamor
  • 131
