No, these cannot share a circuit. The instructions for the cooktop state the following:
A 3-wire or 4-wire single-phase 120/240 or 120/208 volt, 60 Hz AC-only electrical supply is required on a separate circuit fused on both sides of the line (time-delay fuse or circuit breaker is recommended).
The bold is mine. The instructions for the oven state:
This wall oven must be supplied with the proper voltage and frequency, and connected to an individual, properly grounded branch circuit, protected by a circuit breaker or fuse.
Since code requires you to follow the instructions provided by the manufacturer, you can't put these devices on the same circuit. Other brand devices may offer you that option, so it's worth looking through installation manuals if this is a significant requirement for your installation.
