Should I sand the existing paint on my drywall before a re-paint? If yes, what sanding paper grit should I use? Thank you!
LHA
  • 101
The answer depends on what the finish is that the current paint has. It also assumes that the new paint is compatible to the purpose. ( you are not using automotive paint on a wall of your home. Forgive me if I am too assumptive. People will do very odd things.)
If the current finish has a sheen that is flat, eggshell, or matt finish then no sanding is needed.
If the finish is gloss or perhaps even semi-gloss then a light scuff may be in order. For those type of finishes I just use a scuffing pad . I use fine or very fine. Then wipe the wall down with a damp towel.
You are then ready to paint.
RMDman
  • 25,114
  • 58
Sanding (roughing the surface) never harms and it always helps.
The new paint adhesion will be better, and all the handprints (fat) will be removed.
gnicko
  • 5,532
  • 38
asinine
  • 16,852
